First post, by Daniel222potato
Reply 1 of 19, by gdjacobs
S3 Trio or Virge
Reply 2 of 19, by TheAbandonwareGuy
I'm running a ViRGE/DX on my Pentium MMX 166. Haven't had issues so far.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 4 of 19, by clueless1
I tested and reviewed a bunch of PCI graphics cards in DOS. My favorite period-correct cards are:
1. ARK2000PV
2. S3 Virge GX
3. CL-GD5446
If you don't care about being period correct, then the TNT2 M64 beats all of the above. See the link in my signature for more details.
Reply 5 of 19, by Stiletto
Moved to Marvin -> General Old Hardware.
do the Fandango!" - Queen
Stiletto
Reply 6 of 19, by Baoran
Is TNT2 M64 really better than GeForce 2 MX PCI?
Reply 7 of 19, by clueless1
They are probably the same, I think their DOS core is identical.
Reply 8 of 19, by keropi
From my tests I concluded that all the Nvidia cards from riva128 and up to (at least) the GF4 cards all have the sane VGA core. I benchmarked several on my 233mmx , for example a riva128 and a GFMX440 have no difference in speed under DOS.
What is nice about the nvidia cards is the VBE3.0 BIOS - so no need for any TSRs for SVGA gaming.
Personally I changed the riva18zx I was using in my 233mmx DOS build for the S3 Trio3D/2x as the latter has working win3x drivers. Speeds are the same - nothing that makes a difference in DOS.
The S3s, Cirus and ARK vgas that were recommended above are also really great choices.
Reply 9 of 19, by Cyberdyne
S3 and Cirrus chips are the most compadible! Thats all i am saying 😀
And if you wat to cheat, then Nvidia line is for you 😉
Reply 10 of 19, by Cyberdyne
clueless1 wrote:
I tested and reviewed a bunch of PCI graphics cards in DOS. My favorite period-correct cards are: 1. ARK2000PV 2. S3 Virge GX 3 […]
1. ARK2000PV
2. S3 Virge GX
3. CL-GD5446
Ark2000PV what the F....C is that?????
Reply 11 of 19, by keropi
Ark2000PV is a speedy VGA 😁
Gona's DOS TESTS sheet says all IMHO: https://gona.mactar.hu/DOS_TESTS/
Reply 12 of 19, by brostenen
Daniel222potato wrote:
I was wondering if anyone knows a good GPU (that isnt really rare) for my cyrix 6x86 PC build.
Note that my motherboard has ISA and PCI but no AGP.
I am running MS-DOS 6.22 if that matters.
These three cards are good cards for MS Dos 6.22 on a Pentium.
Just pick the one you find that are the cheapest.
You can allways compare: https://gona.mactar.hu/DOS_TESTS/
There might be other cards you want to go for. 😀
- S3 Trio64v+
- S3 Virge325
- Cirrus Logic CL-5446
EDIT: Keropi beat me to.... 🤣
Reply 13 of 19, by clueless1
1. ARK2000PV
2. S3 Virge GX
3. CL-GD5446
Back in the mid 1990s Ark Logic made this chipset which turned out to be the fastest DOS chip of the day. They actually started with a VLB card (ARK1000VL) in 1993, then the ARK1000PV. They didn't last long, going out of business in 1999.
IMO the most famous of this chipset was the Hercules Stingray 64 Video back in 1995. In the mid 90s, Hercules was one of the top video card makers (at least in the US). Diamond also made one with this chip (Diamond Stealth 64 Graphics 2001).
More info:
http://www.vgamuseum.info/index.php/news/item … 8-ark-logic-inc
Reply 14 of 19, by Baoran
That compatibility table made me wonder. Is it only pci and agp cards that have compatibility problems? Can you assume that there would be no such compatibility problems if you would put ISA graphics card on your pentium system?
Reply 15 of 19, by clueless1
IMO, the compatibility chart is a little overblown. Look at the games on there, have you ever played many of them? I think some of the stuff on there is relevant, like side scrollers (Keen) and some of the LCD issues, but the only card I've had actual issues with in actual games I play was the Matrox Millennium II. It's got enough issues that I would never choose it for a pure DOS system.
Reply 16 of 19, by Baoran
I have actually played most of those games back in 90s. Looking at that table the most compatible game seems to be doom. It works with almost all the graphics cards.
Reply 17 of 19, by gdjacobs
1. ARK2000PV
2. S3 Virge GX
3. CL-GD5446
I really like my 5446, but Virge edges it out due to certain models supporting VESA 2.0 with the onboard ROM.
Reply 18 of 19, by awgamer
Card with the best compatibility, decent performance, reasonably priced, readily available, a few of them, one being the Virge/DX. An if only card is the ark2000, good on compatibility and performance but harder to find and odds are priced higher.
Reply 19 of 19, by clueless1
Great point. Also, even if you get a model that doesn't support VBE2.0, it's less costly to enable via software. S3VBE uses less memory than UniVBE or SDD.
And there are measurable differences between the different S3 chipsets. I found the GX > DX > 325 > Trio64V+. The faster the CPU, the bigger the performance gap between them.
