First post, by videogamer555
I thought in 80x25 (80 character by 25 character) text mode, it was supposed to have a pixel resolution of 640x400 (and it appears to be so in DOS Box). However when running DOS in Oracle VirtualBox (when booting to a MSDOS 6.22 floppy disk image), and I measured the width and height of a screencap of the virtual machine's screen window, it appears to be 720x400. And if you look closely, the spacing between typed characters in VirtualBox is a bit wider than the spacing in DOSBox (though the size of the characters themselves is the same). Here's a picture that shows cropped sections of screenshots from each PC emulator (DOSBox and VirtualBox), showing the character spacing.
Which more closely resembles the behavior of real hardware?
