First post, by keropi
Hiya!
I've spent quite some time trying to locate a DOS RAM test program that will work on a 286 and test XMS as well. Anyone knows a program like that other than CHECKIT ?
There are plenty for 386+ machines , 286 is tricky 🤣
TIA for any info/help!
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 2 of 8, by konc
This is only for XMS & EMS, not conventional
The attachment MEMTEST.zip is no longer available
Reply 4 of 8, by keropi
Tried both, both freeze
This is really weird, I have 2 mobos with the HT12 Headland chipset and different ram installed. Every memtest program I tried just freezes the system , just like the chipset detection program that "The Last Byte" memory manager has. Other than that everything runs fine though.
Reply 5 of 8, by MERCURY127
possible NDIAGS (Norton Diagnostics) can help...
Reply 6 of 8, by konc
Weird, I've run memtest on a V20 so it's not that it needs 386+.
Reply 7 of 8, by lowlytech
keropi wrote on 2017-05-19, 10:45:
Wondering if anyone found another memory tester. I too just got a HT12 based motherboard with a 16MHz 286 and checkit and a few other memory test programs just lock the computer up.
Reply 8 of 8, by MSxyz
There is a collection of benchmarks and utilities distributed in a package called "Bench_XT" Most of them should run also on plain x86 CPUs.
MEMSPEED by A. Fominih should work on a 286.
