First post, by TuxedoMask2002
Hello!
First I want to say, that I am from Germany and that my English is very bad. I hope you can understand it.
I have a problem with Dosbox on my System:
AMD Athlon XP2000+
512 PC2100 Cl2 Kingston
MSI K7N2 Delta-L Nforce2 SPP
Sapphire Radeon 9600 pro 128 MB
Windows XP + Sp1 + all important Updates
no programms are working in the background, when I'm running Dosbox
The problem ist that the game I want to Play, called "Formel 1 Manager 96" (but I think it is Dosbox in General) works very slowly. He is reading from the HDD every second and the loading-time in the game is very long. For Exampe, in my old 486 DX 66 Mhz it was able to load the screen in 1 second, with Doxbox it needs almost 10 seconds and the game is nearly unplayable slow. Are there some special options in Dosbox like for the Ressource-Management, which can solve the problem?
I hope you will be able to help me and I they already "thanks a lot"
Greatz to all
TuxedoMask
Reply 1 of 5, by Cthulhus
ok, first, it's a CD Rom game or a disk game ?
If it's a CD Rom game, try to make it in "image" with Nero and use a virtual CD Rom driver like : Daemon Tools (free soft) after that, it's will imporve the time access ...
Now, if the game in directly on DD, just try to increase the CPU Cycle with :
CRTL+F11 -> Reduce
CTRL+F15 -> Increase
You can use : Frame Skip too :
CRTL+F7 -> Reduce
CTRL+F8 -> Increase
Tell me if it's better ?
Sorry for my poor english ! 😉 But, try to speak french like I'm speak english ! 😀 It's not easy !
Reply 2 of 5, by TuxedoMask2002
Ahhh Thank you! Now it is running nearly normal!!!! Thaaaannnnls!
But it is strange that he is reading from harddisk every second, is that normal? (It is a CD-Game).
Greatz
TuxedoMask
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
it's ctrl-f12 instead of ctrl-f15
and reading every second from hd is not uncommon.
Water flows down the stream
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox uses only ram. It's probably the game doing it.
if dosbox is doing it. then you probably have spyware or a virus on your pc. 😀
