First post, by HunterZ
Edit: Continued from Re: Falcosoft Soundfont Midi Player
James-F wrote:
So you do understand some audio jargon, good.
Only enough to be dangerous 😎
James-F wrote:
The line input op-amp rail voltage is at least +-5V so it has plenty of voltage headroom in its analog path before actually clipping the ADC.
If anything, it should be set to ZERO to utilize the maximum input voltage of the line-in.
Okay, I think we were talking past each other in a couple places based on a different understanding/assumption of how PC line-in works.
I now think what you're saying here is that unity gain for line-in should be achieved at a level of 0% or 50%, while I was assuming it was at 100%, because I thought PC sound hardware only applies gain to microphone inputs. Apparently that isn't the case?
In any case, I am fairly confident that 0% line-in level is supposed to be functionally equivalent to mute.
James-F wrote:
my suspicion is that the line-in signal will go through the ADC at full volume, and *then* get scaled in the digital domain by the sound driver according to the line-in level setting.
Exactly.
This is the other place where we were probably talking past each other. You were talking about line-in at 100% causing scaling up from a sampling at unity, while I was assuming that 100% *was* unity, and that anything lower would just scale down an already-clipped digital sample.
James-F wrote:
The JVC probably adds even more amplifiers and multiplexers, that's why it is important to keep the signal chain minimal, MT-32 -> Line-in.
But as you say the JVC is a pro gear, so it should have plenty of rail voltage at the op-amps.
I was skeptical of this statement when I first read it, because I'm using a recording output path for which the JVC provides no user adjustments to the input signal. However, I suppose it's possible that it has amplifier circuits in the signal path to maintain unity gain due to the possibility of needing to send the signal to multiple outputs (speakers, headphones, other recording outputs, etc.).
Reply 1 of 17, by James-F
You can easily test in Audacity whether the Line-In level control attenuates or boosts the signal.
A typical motherboard sound card should have noise floor of around -80dbFS with the line-in levels at zero.
Start with Levels slider at zero and slowly raise it till you see the noise floor volume change in the recording meters.
This point should be the center between cutting and boosting (unity) of the line-in, if it actually works as we assume.
In professional equipment like mixers, microphone preamps, and audio interfaces, the gain trims are only boosting (hence "gain") the inputs, so zero gain actually means maximum available headroom before clipping.
A hot input signal will have the benefit of lower recorded noise floor because we are not raising the input op-amp self noise by adding gain.
Reply 2 of 17, by HunterZ
James-F wrote:
You can easily test in Audacity whether the Line-In level control attenuates or boosts the signal. A typical motherboard sound c […]
Here's what I see - I don't think it lines up with your expectations:
0%: No signal
1%: -129dB
2%: -126dB
3%: -123dB
4%: -120dB
5%: -117dB
6%: -115dB
7%: -114dB
8%: -112dB
9%: -111dB
10%: -109dB
15%: -103dB
20%: -99dB
30%: -93dB
40%: -88dB
50%: -84dB
75%: -77dB
90%: -75dB
100%: -70dB
Also, I can't hear my MT-32 at all at 100% synth and 100% PC speaker volume when line-in is at anything below 3%.
Reply 3 of 17, by James-F
Hm... it appears that 50% is unity because -84db noise floor is typical for on-board sound cards.
Also from the last (Round 3) recordings I see proper waveform without distorted peaks, with 100% synth and lowered input levels (even though the MT-32 itself is distorting).
BTW, What is the noise floor in RMS (noise is measured only in RMS) of your line-in with the levels at max?
On my Focusrite audio interface with the preamp gains at zero (max voltage input) and line-in levels at 100, I get -102db (marked in green).
62.2 KiB
There is another test I want you to do (at your spare time), you need a 1/8" loop/jumper cable (male-male) for it.
1. Loop your PC output and Line-in input with this cable.
2. Play a 1kHz test tone at full volume from you favorite media player.
Here: test tone
3. Check your recording meters and adjust the line-in levels.
Does the rec meter peak with the max signal from the PC?
Do you need to lower the line-in levels down from 100 so they don't peak?
If the max signal from the PC doesn't reach the line-in peak, you can also boost this 1kHz test tone through the JVC and back into the line-in and check again.
What I want to confirm is whether the line-in can boost and cut to accept a wide range of signals.
Reply 4 of 17, by HunterZ
I get about -85dB RMS at 100%.
The loopback test you describe will have to wait until tomorrow. Is there any danger in doing this? I don't want to fry my laptop.
Boosting via the JVC (should it prove necessary) would probably require using the headphone out, because as I said the recording out has no level adjustment. I should be able to manage all this with cables that I have on hand.
I should mention that the sound chip is a Creative Sound Blaster Recon3Di in a Dell Alienware 17 R3 laptop.
Reply 5 of 17, by James-F
Thanks. Spot on with my previous knowledge.
No, it's a standard procedure to measure Frequency Response, Latency, Distortion and other parameters of a sound cards or audio interfaces.
You have to make sure that the "Listen" option is UN-ticked (default) or else you will get endless feedback, if it is ticked you will hear the signal, so you can play with your CM-64 and DOSBox for example.
Besides, the Line-Out should be much less-Hot than the MT-32, moreover, the Line-In has protection diodes on the input so it's not actually clipping at the op-amp rails.
Worry not.
48.85 KiB
@Falcosoft
Please pardon the non FSMP related talk.
Reply 6 of 17, by HunterZ
Loopback test results: It looks like the Line-In peaks if either of the following are in effect:
  • Line-In level at 83+.
  • Headphone Out level at 69+.
Test was performed using the 30-second 1kHz test tone WAV and VLC with the following configuration:
  • VLC mixer volume at 100%
  • No audio filters enabled
  • Peak protection disabled
More data points:
  • Playing the test tone through the loopback cable with Line-In at 50% (which is best guess for unity) and Headphone Out at 100%, I get a level of about -8.5dB and an RMS value of slightly below -11dB.
  • Monitoring the "What U Hear" recording input of the sound card (which is like an internal loopback that appears to be unaffected by the speaker/headphone output volume level), I get a peak level of about -3.5dB at What U Hear at 100% and about -14dB at What U Hear at 50%.
Audacity says the raw test tone data is -3dB. If I try to hit that target instead of 0dB, I get these values:
  • Headphone Out @ 100%, Line-In at 71%, OR
  • Headphone Out @ 57%, Line-In at 100%
If 50% is unity on Line-In, then I guess this means that the Headphone Out of the PC is attenuating the signal a bit? I always thought that headphone amplifiers would put out a hot signal compared to line-level when at 100% volume? Would connecting headphones directly to a line-out really overdrive them in the typical case?
Reply 7 of 17, by HunterZ
After all the work with the JVC, I found a passive 4-input S-Video/composite/RCA A/V switchbox in the garage. Doh! At least it will be more convenient for switching synthesizers because I will be able to keep something that small closer to where I actually sit to use my laptop. Now I just need an extra MIDI male-male cable and a pair of mono phono-RCA cables/adapters so that I can have everything connected at once.
Reply 8 of 17, by gdjacobs
Shame it didn't have AT or PS/2 keyboard switching as well! You'd have a complete solution!
Reply 9 of 17, by HunterZ
Yeah. If I was more of a hardware modder I might re-purpose the internal composite+S-video lines for 5-pin MIDI DIN.
Reply 10 of 17, by HunterZ
Mentioned this project to my wife, and she said she would expect unity to be at a line-in level of 80-something (which may correspond to the 83 I found in my initial loopback test?) rather than 50 or 100. She also confirmed that line level signals are usually hotter than headphone signals.
Reply 11 of 17, by James-F
Thanks for testing HunterZ.
I believe there is no such thing as 'unity' for the recording line-in, there is maximum voltage it can receive without clipping.
Line-Out will (should) output consumer level voltage of 0.316v AC RMS at maximum.
https://en.wikipedia.org/wiki/Line_level
Do you have a digital voltage meter DVM (every man should have one)?
If so please measure the AC voltage output on the tip and sleeve of the 1/8" plug when playing a normazlied 100Hz test tone from your PC at full volume.
You can import (simply drag into audacity) the 100Hz test tone into Audacity and Normalize it (Effect-Amplify), and play from there.
53.65 KiB
Reply 12 of 17, by HunterZ
I assume you mean tip (left) versus sleeve (ground), as tip (left) versus ring (right) would be 0VAC when playing a monophonic recording.
Unfortunately the AC voltage mode of my digital multimeter has a resolution of only 0.1VAC. It shows 0.7VAC with headphone out volume at 100% while the normalized 100Hz tone is playing in Audacity.
Reply 13 of 17, by James-F
Yeah ring-sleeve sorry.
0.7v seems to be twice the voltage of standard line-level output, but it is not unusual, most are higher; I assume the standard is the required minimum.
So the output voltage is not enough to test the line-in maximum voltage input, we need hotter undistorted sine wave at the input.
Do you have a way to boost the line-out and send it back to the line-in?
Reply 14 of 17, by HunterZ
I don't own a signal generator or mic amp or anything, but I probably have the components to breadboard something. I'll take a look around the garage tomorrow if I have time.
What is the expected range between where line-in simply clips and where my PC starts frying?
Edit: Actually, how much amplification would the phono pre-amp circuit on the JVC perform?
Reply 15 of 17, by HunterZ
So I found a bunch of LM324 and a few LM386 ICs in the garage, but this is really too big a project to try to do in one day, so I'm not sure when I'd actually get around to it (plus I don't currently have a good work space for this kind of thing).
Reply 16 of 17, by James-F
Electrostatic voltage is many thousands of volts... its the current that fries electronic not voltage.
I think below 50v generated signal you'll be safe.
I think it'll do.
Reply 17 of 17, by Jepael
ESD events are different. They last only about 20 microseconds so they are short and ESD protection devices can clamp 8kV voltages down to safe levels by shorting the overvoltage to ground. The shorting current can be in the order of 5A and for a brief moment the ESD protection device can dissipate over 100 Watts.
But it would be insane to feed 50V into line input. That should fry any protection and op-amps.
For instance Asus Xonar DG soundcard says full scale input and output voltages are 1Vrms or 3Vpp.
Their USB sound card can have levels of 2Vrms or 5.65Vpp.
