First post, by CkRtech
Finally pulled out some old systems I picked up in an estate sale many months ago and starting doing restore work. I like to start by opening them, poking my head around, and then finally powering them on to see how they run - and I usually do that by using an ATX power supply I keep on the bench for testing. For AT mobos, I just use the same test PSU with an adapter.
With the case and its included PSU selected, I decided to build a 486DX2-66 VLB machine. The King of the Mountain for quite some time. I never had one back in the day - I jumped from a 486SX-33 to a Pentium.
After getting the desired motherboard from another case and cleaning off corrosion thanks to the battery, I mounted the board, tested some configurations, messed around quite a bit, and finally decided it was time to take it off life support and refresh the capacitors in the power supply.
553.3 KiB
Inside the Besttec BPS-2004-4U that was originally running a Pentium 90 machine was a ton of dust and dirt. I easily pulled large dust bunnies out of it by hand before starting to hit it with compressed air. The following photo is after cleaning it for a little bit.
2.26 MiB
The capacitors inside were Panasonic on the primary side and Nicon's for the rest. None of the Nicon caps were bulging at the top, but caps that aren't bulging simply means - that they aren't bulging. That is no indicator of bad or good. They are old, not exactly an award-winning brand, and need to be replaced.
For the replacement caps, I went with Nichicon UPJ for most and Rubycon YXJ for the 1uf ones. My approach when I recap something is to make a "cap map." I draw the board I am recapping, draw circles representing the cap's location and polarity, and then make a chart either to one side to use for recording values. If I can't get the cap's name on the PCB (i.e. "C34") due to it being obscured by another component/glue/etc, I just make my own label just to have a reference for it in the chart. "K1" in my example was a made up name.
The H and D on the page are height and diameter in millimeters. The diameter is pretty important to me when ordering. The height - at least in the case of this power supply - allows for a bit of wiggle room if necessary.
The cap list is later consolidated and a quantity column added to make ordering easier to manage.
280.31 KiB
This unit also has a pretty loud fan - that is pretty much how it is/was/still is when it comes to AT power supplies. Let's take a look at the fan.
408.43 KiB
It was pretty easy to find some stats on it by looking up the model number.
31.4 CFM
28.3 dBA
Man, that is loud. I know some of you guys may have nostalgia for loud power supplies in vintage machines. I definitely do not when it comes to and IBM PC clones. The replacement fan I used was an Arctic F8 (not PWM). It moves slightly less air (31 CFM) but does the job at ~22.5 dBA. Wow. Much quieter.
98.54 KiB
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 1 of 11, by CkRtech
One other recommendation for airflow is to replace the stamped grill with a wire grill.
1.7 MiB
I used a dremel to cut the stamped grill off, and then filed the edges down a bit.
1.9 MiB
With casing mod work complete, the board and fan can be screwed into the case. This shot is just before final wipe down and case closure.
2.26 MiB
One thing that i neglected to take note of until it was time to put the PSU back in case was that the case cutout for the PSU didn't allow enough space for the newly mounted wire grill. I had to do a good deal of slicing and dicing to make enough room for it to fit. You can still see a bit of what was a circle cutout near the rough square that I was forced to cut in order to remount the PSU. Ideally, I would have had better tools and made a neater cut - but "not too ugly" had to be good enough. Despite the odd circle leftover areas, the edges were filed or rounded as necessary.
339.52 KiB
I have been swapping video cards, running benchmarks, and tweaking settings with this recapped guy in place. Glad to finally have it done so I can focus on the system a bit more!
Reply 3 of 11, by TheMobRules
Excellent job. I usually follow a similar approach when replacing capacitors, the little sheet of paper with the "map" and all that. Good tip about the fan grill!
I have a question though: when you are browsing for replacement caps, how do you determine when to use Low ESR vs General Purpose? For newer power supplies there are usually datasheets, but some of these older units use old dodgy brands that may not even exist anymore!
Reply 6 of 11, by CkRtech
Thanks guys. Interested in hearing about any of the recaps/changes/mods that you guys have done as well!
So for non-AT stuff (like I recapped a monitor power board before this AT power supply) I just go with a favorite like Panasonic FR. For this guy, however, one of the guys at badcaps suggested pulling back a bit on the low ESR value and suggested Nichicon UPJ among others.
I was going to summarize some reasoning behind it, but I think I will just post PeteS in CA's explanation verbatim.
Regarding low ESR and some caps being "too good" (bolded text is my emphasis) -
The frequency response of the feedback loop is adjusted to compensate for the effects of various circuit elements. The purpose is to have fast loop response without oscillation. One of the elements the circuit compensates for is the ESR of the output capacitor. One need not precisely match the ESR of replacement caps to the ESR of the originals, but low impedance capacitor technology has improved a lot in the past 20+ years. As good as HE or FR or KY series parts are , they may be so much better than what was originally installed that stability could be come marginal or bad. Nichicon PJ, PS (and PM) and UCC LXV are older series and closer to the impedance of the parts originally installed in the PSU. Nichicon PW, Panasonic FC, and UCC LXZ are very similar and good enough that I'd be nervous about stability.
Badcaps is a great resource for those interested in recapping power supplies. I didn't sweat it and elected to just go with the Nichicon UPJ (a.k.a. "PJ") that he recommended.
Reply 7 of 11, by d0pefish
Nice work! What a coincidence - I've just done the same fan mod to the same PSU (although mine has been rebadged as "Perfect PS220-SM" - inside it has the Bestec BPS-2004-4U PCB).
Maybe the summer weather has made us think about cooling our PCs better. 😀
I agree - the original fan was SUPER loud (although my original one was a Sunon fan with similar specs) and very distracting. I replaced it with a Noctua and it's so much better than it was 😁
Here's my post from yesterday in my 486 build thread about the same PSU:
Another high-end 486 back in action (ASUS GX4 conversion success! Tons of pictures)
I've also been reading the same Badcaps thread, some good comments about the PSU.
I haven't replaced my caps yet, but your list has saved me some work - thankyou for sharing it. 😀
Reply 8 of 11, by CkRtech
Wow! What a crazy coincidence! Glad the cap map helped. Are the old caps Nicon as well?
And that is totally my thread on badcaps. Ha! I didn't post any scope photos here because I didn't pick up any resistors for testing without a load (I just used a less important mobo).
Plenty more AT PSUs to recap. I will probably document them on badcaps or something as well. Not a lot out there on AT recapping. Most of the badcaps guys are of the more modern era when it comes to their PSUs.
Nice case for your build, btw.
Reply 10 of 11, by d0pefish
Yeah, a mixture of Nicon and Rubycon, IIRC,
Oh wow, of course it is! 😵 😵 I didn't even realise how recent it was or that it was you, haha 😀 Thanks for starting it, anyway - it convinced me to keep my PSU when you got the reply that said it looked like a decent design.
Thankyou! 😀 I was extremely lucky to find it.
Reply 11 of 11, by CkRtech
I was happy to see the X Y caps on the input side, and an appropriate rating - 200W Max - for the output power vs the components that deliver the output (Some ATX PSUs claim 400W. You open them and declare "Yeah right!"). Still - I like running stuff by the badcaps guys because they have their heads in those things all the time. They're going to immediately see something that causes them concern and point it out if there is any need to shy away.
From what I have read over the years, the general consensus is "they don't make 'em like they used to" is a phrase that can appropriately describe the transition from AT to ATX PSUs. A good, vintage AT power supply is likely to have a superior build vs a run-of-the-mill ATX if you are simply rolling dice on an unknown. Is that a general philosopy, though? Well, I have only had my head in so many of them. I can't say that it is an appropriate generalization.
What I can say is that it is a good idea to pop the hood on any PSUs that have been acquired secondhand. In addition, I am curious about the build of some of these new AT PSUs that people buy. I just get this feeling that they are more of a "Yeah sure. Here is an AT power supply. Have fun." PSU rather than something that is built well.
