Dosbox & windows driver problem
First post, by sleepy_k
I've just recently discovered this project, and I think it's great.
I've tried a few games succefully with the MT32Dosbox but when I run Sierra's QFG2 Trial by fire it crushes Dosbox when I walk to long in the streets (only in the MT32 version). I Tried instead to use the windows driver - I installed and selected it in the midi mapper but when I try to play the game (either directly under windows or using VDMSound) all I can hear correctly is the drums the rest is either very very very faint or completely wrong.
My system's spec is:
Processor: 2.4 GHz Pentium IV
Motherboard: ASUS P4S8X
Memory: 512 MB RAM
OS: Windows XP SP1
Sound card: Sound Blaster Live!
Video card: NVIDIA GeForce FX 5700
Please help!! 😢
Thanks.
Reply 2 of 44, by Reckless
I really hate to ask (and also hijack someone elses thread) but do you have any plans/strength to bring the Windows driver up to the same level as the DOSBox implementation?
DOSBox is a killer for some games and VDMSound works very well 😀
Many thanks in advance!
Reply 4 of 44, by canadacow
I was unable to crash QFG2 with the MT-32 emulator. Could you give me more information as to what version of the software you're using and what CPU emulation you're using in DosBox?
Reply 5 of 44, by sleepy_k
I'm using the MT32DosBox binary from the project website download page (http://www.artworxinn.com/alex/downloads.htm), but I replaced the SDL.dll and SDL_net.dll with the ones from http://cvs.sourceforge.net/viewcvs.py/stepman … by/sdl_net/lib/ (following a post from this board, I think)
I attached my dosbox.conf file, so hopefully you have all the needed details there.
Thanks for checking it out.
    dosbox.conf.txt
    736 Bytes
    440 downloads
Reply 6 of 44, by robertmo
Do you play the game with both: mt-32 and sound blaster? Cause you have adlib=false - you should never turn adlib off if you use sound blaster. Adlib is a part of sound blaster and in most cases the game cannot work without it if you use sound blaster. Adlib part is for music and sound effects. Sound Blaster part is only for digitalized sound effects.
Reply 7 of 44, by sleepy_k
Unfortunately in QFG2 you can have only one sound device, I tried playing the game only with MT32 so I didn't need the adlib.
I checked the MT32DosBox with the original SDL.dll and SDL_net.dll but unfortunately it's still crashing.
the simplest way I found to crash it is by starting a new game, leaving the katta tail inn, walking north in the plaza into the street and waiting 1:30 - 2:00 minutes. In my case it never fails to crash.
Reply 8 of 44, by canadacow
Ok.. you're right. I was able to make it crash. I'm working on a patch now and should have it fixed by the end of the weekend. (Wife's birthday today so I can't spend to much time on it.. sorry!)
Reply 10 of 44, by robertmo
Is windows driver really needed? As a patch for dosbox it is multi platform. I was wondering what games do you want to use with it. Here is what i have checked:
All adventure games should run properly with dosbox version. They were vga and have no need for fast cpu. The SVGA should already have General MIDI option. VGA adventures (Legend of Kyrandia 2: Hand of Fate) already use General MIDI too. I think it is the same with puzzle games.
First RTS game Dune2 (1992) already have Roland Sound Canvas support. This game is really fast in dosbox. I think there should be no problems with other strategy games too.
Almost the first FPS game Doom has General MIDI support. Wolf3D works fast in dosbox (doesn't even use mt-32). All 2D action game should have no problems with speed I think.
RPG - I have checked Dungeon Master 2 - it has General MIDI support and is not slow in dosbox. Older RPGs shouldn't need faster CPU.
I suppose the only problem may be with flight simulators. X-Wing and Privater alrady use General MIDI. Commanche uses Roland but I wasn't able to run it in windows. Wind Commander I uses MT-32 but it is too fast in windows. I generally think all those old simulators will be too fast or not runable in windows.
Reply 11 of 44, by Reckless
Yes, i think that a driver is the best option for some things... It depends on what CPU power you have and for those [like me] who cannot afford to upgrade their machines, DOSBox isn't a viable option for some (most) games. I wouldn't want to argue about the reason behind DOSBox but I use these tools on a Windows platform to play retro games.
I asked canadacow for info of what the plan was but he didn't respond so I now doubt there will ever be an update to the driver. A shame but that's the way life is! It's such a complicated topic I doubt it'd be a very good idea to unpick the necessary bits from DOSBox and put into the Windows driver - hey, maybe that's not even feasable? Either way, I respect the authors decision to do what he wants with it.
Reply 12 of 44, by canadacow
I really wish I had a functional Win32 driver rather than the straight DosBox configuration. The reason I don't is because the driver source as it stands is unstable. I will play a song until its stopped, but once that happens the driver will crash any application using it. I assume this is due to a memory leak or overrun that cropped up during the driver development hiatus.
Reply 13 of 44, by Reckless
Could you do with some assistance in the matter? I know nothing at all about sound generation but am happy enough with Windows code (been doing it long enough...). Drop me an e-mail if ya like...
Reply 14 of 44, by Karpo_007
If you can't make the windows driver work properly, maybe you could try to fix the soundblaster support on the Dosbox/MT32. In games like Monkey Island 2 or especially in Indiana Jones, Fate of the Atlantis CD version digital sound would be great.
Reply 17 of 44, by Iron
Hmmh I wonder what I have done then coz I'm pretty sure I was trying maniac mansion day of the tentacle cd version which had speech and stuff a week ago.. too bad the game crashed dosbox after a while. Or maybe I'm just totally lost and forgot which box I used.. I'm pretty sure I was trying the dosbox/MT-32 with all games I have that have support for it so I think it was.. and first time i started it there was no music but only sound, then I added the flag that old lucas games used for roland and it had music too. Well too bad I aint home for a few days so I can't check it now.
Or maybe I'm talking about something all different than you guys :P
Reply 18 of 44, by canadacow
The following attachment is the dosbox executable with the bug fixed. I've been short on time recently so I haven't had time to update the site... so bear with me.
As for getting both the sound blaster and MT-32 playing simultaneously, if I remember correctly, such a task was nearly impossible with the real hardware too!
Sorry for the late post. I'll try to keep you guys posted!
    dosbox.exe
    728 KiB
    508 downloads
Reply 19 of 44, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
It needs WPCAP.DLL, PACKET.DLL (possibly other things as well).
Is WinPcap (http://winpcap.polito.it/install/default.htm) needed?
Mirek
Edited: removed some confusing questions from this mail.
