First post, by PvvS
Hello, I bought one XT card, among other things. Finally it is ITK-302 RAM / ROm disk ... Unfortunately somebody probably pulled 2 EPROMs. In others, according to the contents of the IBM DOS 3.3, but also with MS RAMDISK and possibly IPX Netware support .. How do I know stuff there. Did not anyone come across at least the manual or the ROM?
    219.66 KiB
    244.01 KiB
Reply 1 of 2, by matze79
Simply Place ROM's with your OS on the Card ?
i don't think there is something removed.
You may simply need to burn new rom's.
i would remove this accumulator before it is leaking and destroys your card.
Reply 2 of 2, by PvvS
Thanks for the reply. But there is more memory in the card, and there is a RAM disk on the card. I would like to make it fully operational. By burning content to EPROM, the problem is not just about preparing data for the disk. Meanwhile, I just find out which jumper settings are set up from A to D.
The battery has long been removed, a new one is in place, but I will put it in the functional card.
