First post, by Munwele
Hello, I am currently having a problem with my ZX Spectrum.
This particular monitor has an RGB connection at the back (pictured below), and I'm trying to connect the Spectrum to it using some sort of adaptor that came with the Spectrum itself (also pictured below). When I connect the Spectrum to the monitor, I get no image. What could the problem be?
The Spectrum is a 128+ Toastrack version, if it helps.
Reply 1 of 2, by keropi
The push button on the right of the rgb input, it's de-pressed right? What 1084 monitor is this?
edit:
I see now that you need 75ohm resistors in the RGB and SYNC lines , if you open your cable's DB9 shell can you see resistors inside?
Reply 2 of 2, by Munwele
edit:
Thanks for your reply, the monitor is a Commodore 1084S-D2, to be exact. Below are two pictures of the insides of the DB9 connector.
I see no resistors, and one of the cables (the brown one) is not connected to the DB9 connector.
Sorry for the blurry picture.
