First post, by videogamer555
When running the debugger version of DOSBox, to actually activate the debugger, you must press Alt+Pause. However I have a Dell Inspiron 7559 laptop, which does not have a Pause key. Is there any alternative keys I can use to activate the debugger? Or did the developers of DOSBox not take into account this scenario, when creating DOSBox?
Reply 1 of 1, by videogamer555
Ok I figured it out. You have to use Ctrl+Fn+Alt+F11 to activate debugging mode, because Ctrl+Fn+F11 is equivalent to Pause on my computer.
