Ultima Underworld (I)
First post, by MF1979
Hello. I am having problems with sound for this game. I am using DosBox to run the game, and it seems to run fine, but without all sound. I'm running Win XP. I have looked around the forum and have tried several things, but none seem to work. When I try to access the Uwsound.exe files via DosBox, I get another error, telling me that it is an invalid command, yet I am able to open and run Uw with no problem with this method.
I have tried VDMS as well, to see if I could fix the sound somehow that way. When I try to open any of the .exe files with VDMS (after copying the entire Cd to the C drive) I get an error: "could not find configuration file." Perhaps I am just a bit of a newbie with these programs, but I am unable to open the files to edit the sound options.
Thanks!
Reply 1 of 1, by eL_PuSHeR
Ultima Underworld 1 and 2 work perfectly using VDMSound. And i am pretty sure they should work properly using DOSBox too. Did you run any patches?
