First post, by TheAbandonwareGuy
I had my AST VGA from 1993 turned on earlier to watch a couple of episodes of Beyond Belief Fact or Fiction in a true-to-life 1990's manner. Anywho I got up and saw this when I looked down:
https://m.imgur.com/gallery/HAs4d
That's a view from outside the top cooling vents towards the very back. I'm assuming that's the base of the CRT correct?
Should it glow like that after only perhaps an hour and a half of use? The glow disappeared immediately when the display was disengaged but that's kind of scary. I've worked on newer CRTs with the casings off and never noticed any glow or light of any type, but I guess I've also never done it in the dark though I would think such a glow would certainly be noticeable in lighter conditions.
Do I have a serious issue here or is it just part of how these older CRTs function? I remember someone here not to long ago mentioned they had once seen an IBM 5150s neck begin to glow red hot and I must wonder if I'm observing the exact same phenomenon here. If that's heat and not just light passing and refracting through glass that I'm seeing I'm assuming that isn't safe at all.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 1 of 3, by 133MHz
That's normal. The CRT filament gives off a reddish-orange glow when powered. Some are easier/harder to see depending on the thickness of the neck itself, the amount of stuff attached to it, and the layers of dust that had built up over time.
http://133FSB.wordpress.com
Reply 2 of 3, by keropi
perfectly normal , infact if there is no glow then it's a problem 😁
Reply 3 of 3, by Jade Falcon
Rank BANNED
BANNED
That all right, it's only a problem is it gets brighter. If it get brighter than at normally the tube may be on its way out.
