XT IDE to AT IDE upgrade
First post, by Stojke
Is it possible to upgrade an XT-IDE controller to an AT-IDE controller to use in an 8086 computer? I have an WD FileCard 30MB but the drive is dead and I would like to upgrade it if possible to support an 44MB AT IDE drive that I have (WD93044-A).
The card I have looks something like this, only it has an additional header populated:
Reply 1 of 7, by Imperious
8088 and 8086 are XT computers. You need a 286 at least to be AT. I made up one of those Lo-tech 8-bit cf adaptors, it worked even in my 486.
Reply 2 of 7, by Jo22
You're right, but I believe Stojke is asking if it is possible to upgrade 8-bit XT-IDE to support AT-IDE hard disks instead
of XT-IDE hard disk (which CF cards are often compatible with).
https://en.wikipedia.org/wiki/Industry_Standa … itecture#XT-IDE
http://www.vcfed.org/forum/showthread.php?397 … T-IDE-vs-AT-IDE
Reply 3 of 7, by Stojke
I saw some bios edits that enable AT disk support of large capacity. The computer I want to do this mod on is an Philips NMS9100. It also has an integrated IDE-XT interface.
Reply 4 of 7, by Jo22
Cats love it, so it must be really awesome! 😁
https://www.youtube.com/watch?v=y3oMhyviL0s
Btw, I've found contradicting information regarding that machine.
Is your model an XT or an AT model ?
XT: http://trelohra.blogspot.de/2015/06/philips-n … l?view=snapshot
AT: http://www.pcnoproblema.com/2014/04/philips-a … -riconosce.html
I see, that's good. Unfortunately, I don't own any XT-IDE stuff so I can't say anything about the matter.
I do own an EPROM programmer, though. So if you need a custom BIOS chip for XT-IDE, just tell. 😀
Reply 5 of 7, by Stojke
Its an 8MHz XT model.
Reply 6 of 7, by keenerb
I've wondered this as well. The WD ATA and XTIDE 8-bit controllers seem identical except for the IC installed at U5.
Reply 7 of 7, by rmay635703
I’ve often wondered if you just ran the wires from the AT ide ribbon cable to the matched XT IDE wires on the motherboard leaving the upper 8 bits NC if you would just get a half capacity ide drive?
