First post, by SRQ
Or XP? Through several systems, I have never seen these two cards- which work 100% fine SLI on win98- work on 2K or XP together. They are not the same manufactuer, but are the same model- both being 12mb units.
I tried the 4.00 drivers and Koolsmoky’s Voodoo2 XP driver, what else should I try? Is it just impossible to SLi two non-matching cards under 2k?
E: This only needs to be for Glide, so the drivers lacking DX support is totally fine.
