First post, by JYoder
JYoder
Offline
I have a Pentium 4 1.70 GHz with XP. I've run DOSBox on it and things have worked fine. However, I noticed for games that require text command input (such as Hugo's House of Horrors and Ultima I) the text input area is messed up. I can type commands in and they work, however, I can't really see what I'm typing, nor can I use backspace. Is there some simple fix / setting I can make to take care of this?
BTW, I love DOSBox -- it's very slick.
