First post, by wiebermensch
It looks like redirection part is the weak point of current DOSBox.
For example, I made a text file which contains debugger commands like this:
------------------- input.txt ------------------
p
r cx
10
Then I redirected this file as an input to debug.exe(Windows DOS debugger) like this:
c:\winnt\system32\debug.exe < input.txt
On command window of Windows, it works.
On DOSBox, it doesn't work!
p.s. I suggest that DOSBox had better support copy to / paste from clipboard feature in next version...it's my hope
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Yes, it is not implemented. We know.
Also it does not belong here, moving to Dosbox Development.
Mirek
