First post, by mburress
Info:
I am using Dosbox .61
CPU 1.8 Ghz AMD 2200 (dosbox 10000 cycles)
my hard drive is f: my cdrom is e: I am using the -t cdrom switch to mount
the cd although it doesnt look like its needed
hard drive is 80 GB.
I mount each of the drives as their correct letter but ive tried mounting hd as c too, doesnt help.
I am trying to install World of Aden: Thunderscape by SSI. Before installing it does a hardware test. Everything checks out until it tries to scan hard drive for available space (i have plenty) i get an "error reading drive" msg and install then quits without installing. If this helps i believe the same install program was used for the Ravenloft games and Menzoberranzan. I have read the readme that came with dosbox and the FAQ on the sourceforge website. I have not found a message elsewhere on the board answering the question although a similar question was posted concerning ravenloft: strahds possession.
