Q3A Audio lags in Win98
First post, by Elia1995
I got this weird issue with Quake III Arena on Windows 98: the game runs quite smooth, but the audio sounds horrible and laggy.
I am using a CT4750 as sound card and an nVidia GeForce FX5500 as GPU.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 1 of 8, by darry
I would try a different driver or playing with the audio acceleration slider to see if it helps .
Reply 2 of 8, by Elia1995
Nothing seems to change
EDIT: now the sounds sound less choppier, but it LAGS as it comes late than when it's supposed to be heard, it got a delay: for example if I shoot a rocket, I hear the sound of the rocket some seconds AFTER I shoot it instead of hearing it correctly.
Reply 3 of 8, by darry
Long shot :
Does disabling full duplex mode in the driver properties change anything ?
Reply 4 of 8, by Elia1995
I can't find such setting in the Multimedia properties on Windows 98SE, where is it ?
Reply 5 of 8, by darry
The setting is in the Sound Blaster 16 device properties in Device Manager .
But I just realized the CT4750 is a SB128, so that does not apply, sorry .
Reply 7 of 8, by leileilol
A3d won't matter if it won't initialize on inappropriate hardware.
Try changing s_mixahead and s_mixprestep, and set sound acceleration to max (setting it to minimum would lead to rather latent sound output)
long live PCem
Debian's fucked
Reply 8 of 8, by darry
I seem to recall that a software only implementation was present .
This .inf refers to an a3d.dll which would seem to corroborate this :
http://contents.driverguide.com/content.php?i … %2FSbaPci9x.inf
as do the docs for HP's OEM version :
http://pdfstream.manualsonline.com/2/2b1d1d6a … 97e01c0037b.pdf
and this thread :
Ensoniq / Creative AudioPCI
