DOSBOX and XP
First post, by Udo
Sorry for my bad writing (German Gay).
I have a program that need the ESC and the F1 - F10 Keys.
This program needs in the config.sys:
DEVICEHIGH=C:\DOS\EMM386.EXE RAM X=C000-C7FF X=D800-DBFF
This is a special program that we need for reservation in a bowlingcenter.
Thanks for help
Udo
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well that ems line isn't needed in dosbox as it has very good ems by itself.
Did you try to run the program actually inside DOSBox ?
The F numbers might be a problem. If it doesn't work try loading xkeyb.com else wait for the next version.
Water flows down the stream
Reply 4 of 4, by Udo
Ok, i have take the xkeyb. But sorry the program that must run under dosbox dos not work.
i need the keys in the red box. an the first key that must work is the "esc" key.
So i think i must wait for the next.
