First post, by ProfessorProfessorson
After years of owning this card and doing much of nothing with it, decided to run this card doing a more ideal 800x600 test to find the sweet spot where it doesn't dip below 30fps in anything game wise. I think I was successful for the most part. Its possible the lowest dips in games could also be due to the Pentium III 1ghz. Driver used is V2.01.21.0007.
Test bed as follows:
KYRO II 32mb AGP
Slot 1 Pentium III 1ghz 100fsb
256mb Pc100
Intel 440BX2
Vortex 2 soundcard
Windows 98 SE
All test run in 800x600. Games settings were maxed out, and 32-bit color was set when possible.
2017-08-07 20:04:26 - LEMANS 24
Frames: 4667 - Time: 157791ms - Avg: 29.577 - Min: 30 - Max: 30
maxed out 800x600 32-bit
2017-08-07 20:20:30 - LITHTECH (No one lives Forever)
Frames: 15345 - Time: 306084ms - Avg: 50.133 - Min: 14 - Max: 88
2017-08-07 20:40:09 - UNREAL TOURNAMENT
Frames: 15587 - Time: 194298ms - Avg: 80.222 - Min: 35 - Max: 181
2017-08-07 20:46:49 - DETHKARZ
Frames: 7240 - Time: 89890ms - Avg: 80.542 - Min: 32 - Max: 154
2017-08-07 20:52:22 - SEGA RALLY 2
Frames: 4138 - Time: 69650ms - Avg: 59.411 - Min: 40 (less then 1 second dip caused the 40 fps, otherwise always stayed at 59.4/60fps)- Max: 61
maxed out 800x600 (no color option)
2017-08-07 20:55:20 - QUAKE2
Frames: 8795 - Time: 61817ms - Avg: 142.274 - Min: 65 - Max: 274
maxed out 800x600 16-bit
3D Mark 99
800x600 16-bit
7445 3D marks
race 82.6fps
first person 67.8fps
3D Mark 2000
800x600 32-bit
5178 3D marks
Game 1 - Helicopter - Low Detail: 103.3FPS
Game 1 - Helicopter - Medium Detail: 66.3FPS
Game 1 - Helicopter - High Detail: 27.9FPS
Game 2 - Adventure - Low Detail: 131.5FPS
Game 2 - Adventure - Medium Detail: 64.7FPS
Game 2 - Adventure - High Detail: 37.8FPS
Reply 1 of 11, by Reputator
This is truly one of the most interesting retro cards of its time, and it honestly deserves more attention. I'm glad people like you have benchmarked it, and Phil made a video about it, but it certainly wouldn't hurt if more owners came out of the woodwork and talked about their experiences with it.
https://www.youtube.com/c/PixelPipes
Graphics Card Database
Reply 2 of 11, by The Serpent Rider
And now tiling was fully adopted by modern GPUs.
Reply 4 of 11, by leileilol
Texturecoord precision wobbles are not nice to see with old games. I wouldn't recommend it for "retrogaming". It's also unstable with anything UnrealEngine2. Many of the features it supported ended up being barely used by games anyway (EMBM, 8-stage multitexturing, etc)
It could be seen as a PowerVR TNT2 Ultra at best, especially without the fun SGL stuff.
(also its much touted "Internal True Colour" is just 32bit buffer->16bit dither->DAC filter (overmarketed as some crazy super secret tech), so basically "22-bit"'ing it there.)
Reply 5 of 11, by The Serpent Rider
It's a crazy mix of everything. Flawed linear filtering of GeForce, godlike 16-bit color of 3Dfx, capable of doing Dot3, EMBM, S3TC, SSAA. 32mb version does not suffer as much as competitors when VRAM hits it limit.
Reply 6 of 11, by ProfessorProfessorson
Just to note, per the next thread I am fixing to start, the Kyro II also beats the crap out of the Geforce 4 MX 420 in a large chunk of the test I did..... Given the price of the two cards at the time they were on market, the Kyro II seemed much more like the better bang for buck option in the budget card range. Not bad considering Kyro II was released first at what, a year earlier?
Reply 7 of 11, by leileilol
You're not exactly comparing them in an app it wants (3dmark2001 will show the Kyro2 getting stomped here)
Reply 8 of 11, by ProfessorProfessorson
I'm gunning for Direct X 7 and prior only. Thats the type of stuff I run in 98. Thats why you're not seeing me run anything after 2000.
I wouldn't even consider throwing 3D Mark 2k1 into any kind of mix anyway unless I was using Windows XP, a Athlon Xp at least and a card capable of pixel shader support, because CPU speed does play a big role in that test as does pixel shader power for the end test score. 3D mark 2k1 is aimed mainly at testing Direct X 8 hardware and faster processors in general, and both cards do so poorly in that test that its pointless to me unless I want an exercise in frustration. Also, I'm not comparing them at all to each other in some kind of specific project, thus two separate threads. I have some cards here I will be testing as I go before I box them back up. Thats why I am posting these threads.
Also, the MX 420 beat the Kyro II in 3D Mark 2000, which I expected due to Hardware TnL but it did not win by some overly massive margin. I cant play 3D Mark 2000 though, so I'm more inclined to not pick a card based on just that benchmark when I finally decide on what to leave in this build. You know what I can play? Dethkarz, No one lives Forever, and Unreal Tournament. I have to look at the majority of the games I'm playing, and see which card runs the most at the best performance with the least amount of frame dips per session. I more or less just run 3D mark 99 and 2k out of habit and to make sure things are working correctly and stable. I tend to run it before I install any games.
But yeah as far as the two cards go, I'm just noting an observation between the two as I go, and as of now the Kyro II is doing better at DX 7 at the majority of the games. Gameplay also feels smoother on Kyro II to me. There are less FPS dips on it then on the MX 420 in my experience. YMMV. If you plan to run mainly hardware TnL extensive games, the MX 420 may better suit your needs. But then again, so would a Geforce 3.
If you really are interested though in seeing how future proof the Kyro II was compared to the MX 420, you can check these videos out:
https://www.youtube.com/watch?v=B7mC0Eqnues&t=697s
https://www.youtube.com/watch?v=TPSVze0NZyA
https://www.youtube.com/watch?v=a_bkKD6C7Ng
That guy ran the card with a Pentium dual core. Was interesting to see the results he got. Basically if you know the MX 420 can run those games in the videos better then Kyro II on a similar setup, then you have all the info you need to know concerning DX 8 on up, if thats what your goal would be.
Reply 9 of 11, by ProfessorProfessorson
Something I should mention about the Kyro on the off chance someone feels encouraged to buy one on a whim. If at all possible try to google to see if your motherboard has compatibility issues with the card prior to purchase. Every Kyro II card I have ever owned has been somewhat picky about what motherboards it will work with, similar to how the Rage Fury MAXX acts. If you do pick up a Kyro, and its not working in your setup, if possible try to test it in a couple other boards before writing it off as defective.
Reply 10 of 11, by Reputator
Ah yes, good to know. This issue can sneak up on a person who isn't used to dealing with, shall we say, off-kilter graphics cards.
Reply 11 of 11, by Fusion
Also, I had a fan just quit on a Kyro 1 64MB after only 4-5ish years of use. That caused the card to slow die as I gave the PC to a family member. 😒
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
