First post, by bushmac
Hey guys, I have been hitting my head against the wall about this and need some help.
I am currently trying to configure Earthseige via SOUNDSET.EXE in MS-DOS mode in Windows 98SE. To my understanding, SOUNDSET only auto-detects sound settings. While I would expect my Sound Blaster settings to be detected, my Microsoft Sound System configuration is detected instead:
255.71 KiB
The current settings SOUNDSET.EXE for Earthseige reports upon detect...
342.81 KiB
My current DOS settings for my sound card
I currently do not hear any sound when a game is configured to use my Windows Sound System configuration (Earthseige does not play sound. Tomb Raider, for example, locks up with a high pitch noise when testing sound settings with Microsoft Sound System. SB works great!) These are my current questions:
1) Is there a way to manually configure sound settings for Earthseige? I see there is a RESOURCE.CFG in the root directory of the game, though I have not found any guide for identifying driver values to change this file (if RESOURCE.CFG is what's consumed by Earthseige that is).
2) What should I start looking into to get my Windows Sound System settings working properly?
3) Is there another configurations/variables I need to have set in autoexec.bat or config.sys to have SOUNDSET.exe run as intended?
4) Are there other factors that I am not considering?
Any and all help is greatly appreciated. This is a pretty cool community.
My System:
OS: Windows 98SE 4.10.2222 A
Sound Card: Audician 32 Plus ISA (YAMAHA OPL3-SAx WDM Driver)
Video Card: NVIDIA GeForce FX 5200 (AGP)
RAM: 512 MB SDRAM
CPU: Intel Pentium III E 700 MHz (Slot 1, 100 MHz FSB)
MOBO: Dell OEM SE440BX-3
AUTOEXEC.BAT
SET BLASTER=A220 I7 D3 T4
LH C:\MOUSE\MOUSE.COM
CONFIG.SYS
DEVICE=C:\PROGRA~1\YAMAHA\OPL3SAX\SACDROM.SYS /P0 /IOFF /A0
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM388.EXE NOEMS
DEVICEHIGH=c:\VIDE\VIDE-CDD.SYS /D:MSCD001
DOS=HIGH,UMB
Win 98 Box
Windows 98SE
Voodoo 3 3000 AGP
ATI All-In-Wonder Rage II + DVD PCI
512 MB SDRAM
PIII E 700 MHz
Dell SE440BX-3
Win XP Box
Windows XP Home SP 3
Radeon 9800 Pro 256 MB
2 GB DDR
P4 HT 3.2 GHz
Gateway D865GLC
Reply 1 of 3, by sf78
I'd try I5 D1 for starters, but I've also had some difficulties getting the Audician to work correctly with some games. I've since switched completely to regular Sound Blasters and ESS cards for basic SB/SB16 needs and haven't had any problems since.
Reply 2 of 3, by bushmac
Heh, thanks for the advice sf78. That got me thinking about looking at my sound settings again and noticed Earthseige was looking at DMA channel 1 when I set WSS to DMA channel 0. While this does not solve how to get Sound Blaster specific settings setup on Earthseige, I do now have sound via WSS. If anyone else has any insight, that would be super. Thanks again guys.
Win 98 Box
Windows 98SE
Voodoo 3 3000 AGP
512 MB SDRAM
PIII E 700 MHz
Dell SE440BX-3
Win XP Box
2 GB DDR
P4 HT 3.2 GHz
Gateway D865GLC
