First post, by olivil
I have a PC with an SB16 and a GUS MAX.
Everything worked fine until I wanted to try replacing the SB16 with an AWE64. Almost everything worked but I seemed to have an Adlib conflict with my GUS so I settled on the SB16, and Iput that back in. Only now there's no MIDI coming out the gameport to my SC-55 (it used to work!)
I checked my cabling and everything seems fine, however there is no MIDI activity on the SC-55. Using a MIDI waveblaster board, everything works so I know my MIDI port address is set correctly.
I am puzzled, what should I look for next?
Here are the lines that are related to soundcards in my autoexec.bat
REM ===== SB16 Setup =====SET SOUND=C:\SB16SET BLASTER=A220 I5 D1 H5 P330 T6C:\SB16\DIAGNOSE /SC:\SB16\MIXERSET /P /QREM ===== Gravis Setup =====SET ULTRASND=240,6,7,3,7SET ULTRADIR=C:\ULTRASNDSET ULTRA16=34C,0,0,1,0C:\ULTRASND\ULTRINIT.EXE -dj
My guess is I messed something up editing my config files to and from the AWE64 but it is seriously going over my head!
