First post, by shprotanu
Hello everyone,
This is my first post here 😀
I found this great launcher menu for games under DOS called Kymaera. It was designed as an emulator frontend but it can launch any application so it should be able to work for DOS games also.
It has a DOS version and a Windows version and you're supposed to install the Windows version first, copy the DOS version in the same folder and set it up in Windows before running it in DOS.
It works in Windows but I can't get it to run in DOS.
I've attached a screenshot of the error I get.
I'm trying to get it running on a P3 with Win98 and DOS
I'd really like to get this thing working because it looks great and it has a lot of features, it's the only DOS launcher menu type application that that I found that has screenshots for the games.
Any help would be greatly appreciated!
Cheers!
https://sourceforge.net/projects/kymaera/?source=navbar
http://kymaera.sourceforge.net/
    10.79 KiB
