AWE64 clicking on FM
First post, by olivil
Hi!
I have this AWE64 Gold that won't stop "clicking" (around 4 times per second) when FM sound is playing.
Here's my system:
Asus P5A-B motherboard
Pentium 200 MMX
32 MB RAM
SB AWE64 Gold
GUS MAX
S3 Virge 2MB PCI
3COM etherlink III PCI
I tried a couple of things that didn't work:
1- Setting the SB IRQ (5) to Legacy ISA in my BIOS
2- Changing the IRQ from 5 to 7
3- Removing the GUS from my system
At this point I'm pretty sure the card has a problem, even though everything else works perfectly, and no clicking occurs in non-FM sounds.
The card looks okay physically.
Any of you experienced something similar?
Reply 1 of 16, by Jo22
Sorry, I've got no AWE64 at hand right now. 🙁
Maybe setting the ISA bus frequency to ~7 MHz changes something.
Reply 2 of 16, by derSammler
Important info missing: when you say: "when FM sound is playing", how do you play FM sound? MIDI player, games, etc.?
Also, it seems you did not try yet without the 3COM, did you?
Reply 3 of 16, by olivil
No I mean FM (Adlib) music! Anything else is ok. I did not try it without the 3COM, I will.
I dont think my motherboard supports changing the ISA bus frequency, or at least I haven't seen any options in my BIOS.
Reply 5 of 16, by gerwin
Yes, I perceived the same FM issue when I tried an AWE64 gold. But I did not try to solve it. I swapped out the AWE64 gold for another soundcard. I know this does not help much.
Reply 6 of 16, by olivil
Deksor wrote:
Is your FSB higher than normal ? (Like 75MHz for example)
Nope, I'm on "stock" 3 x 66 MHz for my P200 MMX.
That's interesting! Do you remember your PC configuration at the time?
E: Okay I have a breakthrough! I tried without the 3COM card, which didn't change a thing.
However I just noticed that I don't get the clicks testing FM with Sound Blaster Diagnose. Also from that point on I don't get the clicks until I reboot!
To be clear here's what I'm doing:
1. Boot
2. Test FM (wolf3d), with clicks
3. run diagnose.exe, with the Synthesized Music test, no clicks
4. Test FM (wolf3d), no clicks
5. Reboot
6. Test FM (wolf3d), with clicks
7. ....
This is a config problem, I'll investigate further 😀
Reply 7 of 16, by derSammler
Are you calling aweutil.exe in your autoexec.bat? If not, the FM part may not be resettet correctly, which may be the cause of your problem.
Reply 8 of 16, by olivil
Yes I am. Here's my AWE64 related stuff in my autoexec,bat
SET CTCM=C:\CTCM
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E
C:\CTCM\CTCU /S /W=C:\WINDOWS
C:\SB16\MIXERSET /P /Q
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL.COM /S /R:10 /C:10
I tried messing with the order of things to no avail.
Found out that running aweutil /S after the diagnose workaround brings back the clicking.
Reply 9 of 16, by olivil
Okay so here's what I found:
In my autoexec.bat..
If I don't run AWEUTIL: no FM, of course
If I don't run AWEUTIL, but then run diagnose.exe: The card is initiated perfectly, but I have to run the program, wait for the tests, exit, ...
If I run AWEUTIL: FM with clicks
If I run AWEUTIL, then diagnose.exe: The card is reinitialized, I lose my reverb and chorus effect, but I get no clicks
I'm fine with having no chorus or reverb.
I'd have to find a way to automatically initialize the card with only diagnose.exe, is that possible?
Reply 10 of 16, by gerwin
Weird stuff. But at least there might be a solution in the line of what you are currently trying.
What if you just switch the order of these two lines, like this:?
C:\SB16\DIAGNOSE /S
The system that I was using at the time was i440BX based. Either from Aopen or Gigabyte.
Reply 11 of 16, by olivil
Same problem using that order.
I even tried moving my AWE64 block in my autoexec.bat to the end and it exhibits the same symptoms.
Reply 12 of 16, by olivil
Fixed by updating AWEUTIL from 1.20 to 1.35 ...
Reply 14 of 16, by Simmerhead
olivil wrote on 2017-09-03, 14:33:
Where do you find AWEUTIL 1.35? I've got the same problem.
Simmerhead
¤ VGA-era DOS Gamer
¤ Vintage PC Hardware Collector
¤ Big Box DOS Games collector
Reply 15 of 16, by Joseph_Joestar
Simmerhead wrote on 2021-01-31, 19:08:
This link should lead you to AWE64 Gold driver section of Creative's website.
If you select "DOS" in the pull down menu at the bottom, you should be able to download s64basic.exe and ctcmbbs.exe. After you unpack and install both, you will get aweutil.com v1.36.
This is assuming you're running MS-DOS 6.22. If you're using Win9x, you will need to download 95dosapp.exe instead.
My retro stuff
Reply 16 of 16, by Simmerhead
Joseph_Joestar wrote on 2021-01-31, 19:31:
This link should lead you to AWE64 Gold driver section of Creative's website. […]
Thanks a bunch!
Simmerhead
¤ VGA-era DOS Gamer
