First post, by Avoozl
- Newbie
I wanted to try running the game with a texture filter but every filter I select causes what appears to be lines around tiled textures, with "forced bilinear" of all texture filter options it's the least visible but they are still noticeable as seen in the below image on the ground texture, the program is running under the direct x options of dgvoodoo.
I want to know if there's an option in dgvoodoo to eliminate this issue.
I am also on Doomworld.
