Lego Island 1 windows 98se
First post, by jamespoo
game runs fine other then this problem im having
when building say helicopter or jetski sometime it takes quite a number of clicks before i can drag the peaces into place
and once i built the jetski i keep clicking everywhere on it but i cant hop in it
anybody know why this is im using my original cd i got back in 1999
Reply 2 of 21, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 3 of 21, by RJDog
I've heard this game is somewhat speed sensitive and might behave poorly on faster systems. What kind of system are you running on?
Reply 4 of 21, by jamespoo
AGP 4x 32mb video p4 cpu
Reply 5 of 21, by weldum
you should run that game in a computer that matches closely the system requirements like a pentium 133 or so
here is some info: https://pcgamingwiki.com/wiki/Lego_Island#Ins … ions_of_Windows
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 6 of 21, by RJDog
Confirmed, runs great on my P-MMX 233.
Reply 8 of 21, by weldum
thanks but its impossible to find a system like that here in new zealand
Well, you could try using DosBox with Windows 95 installed. The game needs a slow processor and uses software rendering, using dosbox that way should do it well.
Reply 9 of 21, by leileilol
DON'T
Reply 10 of 21, by Jade Falcon
Rank BANNED
BANNED
leileilol wrote:
DON'T
More of your craziness, Nothing wrong with running windows in dosbox. I use dosbox to run 16bit windows apps alot. works fine. with win3.1. 9x it a little tricky to get running at first, but once you get it up and going its fine.
Reply 11 of 21, by gdjacobs
Of course if you run into any problems, you're on your own.
Reply 12 of 21, by Jade Falcon
Rank BANNED
BANNED
There are plenty of people out there that would be willing to help
Here is a guide on running 95 in dosbox
Guide - Windows 95 on DOSBox 0.74
Site with some info on running 95 in dosbox
http://dosbox95.darktraveler.com
And its listed as supported on the dosbox site
https://www.dosbox.com/comp_list.php?showID=3120&letter=W
Reply 14 of 21, by Jade Falcon
Rank BANNED
BANNED
Expecting support form a free open source emulator devs/maintainers is backwards thinking to begin with.
However there are a number of folks that use dos box to run 9x so finding help would not be all that hard.
And let's be honest dosbox is a dos system emu, 9x is at it roots a dos app.
95 Is even marked as being supported on dos box's website.
Reply 16 of 21, by Jade Falcon
Rank BANNED
BANNED
States dos box supports running 95 in version .74 .73 and .65
and 9x is differently a dos app, just a very overly complicated poorly written one.
EDIT:
But now we are getting off topic and none of this is helping the OP.
Reply 17 of 21, by DosFreak
The compatibility list is user submitted. If the op wants to run the game in an emulator then it'll likely run fine in an emulator that supports 9x as a guest like pcem.
Also no it definetly is not. You should read up on it since it's pretty interesting.
Make your games work offline
Reply 18 of 21, by gdjacobs
Jade Falcon wrote:
There are plenty of people out there that would be willing to help […]
And if you run into a bug specific to Win9x, who's going to patch it?
DOSBox is great for DOS because of speed control and support for DOS relevant hardware. Why try to force it into doing something it's not intended for (unless you want to know if it can be done)? Other visualization and emulation platforms are so much better for hosting Windows. Find one that allows CPU throttling and you're good.
Reply 19 of 21, by Jade Falcon
Rank BANNED
BANNED
What are you going to do when X dos app has a bug?
So many apps have problems with dosbox but I don't think its devs are going to do anything. .74 has been the newist version for 7 years now.
