First post, by tomoa
I built a new machine:
Asus CUBX-E
Pentium III-S 1400 MHz (modded for PGA370) SL5XL
512 MB RAM Hynix PC133 CL2
Geforce FX 5900XT@5950 Ultra
SB AWE 64
System can be OC to 140 FSB on this configuration. When I put Infineon RAM PC133 CL2 which worked fine with Abit BX133-RAID, I could make OC to 125 FSB only.
System: Windows XP SP3, forceware 81.85.
Benchmark: Futuremark 3DMark 2001SE default settings - 10253 score
    3.62 MiB
    1.43 MiB
    1.95 MiB
    3.41 MiB
    411.49 KiB
Poland , http://komputery-retro.ddns.net/ http://komputery-retro.ddns.net/blog/ , I like old games and old computers 😀
Reply 2 of 15, by tomoa
Neuromancer wrote:
Hello, i have exact the same machine here. I also modded the Socket and the CPU. Mine is running at 1.6V 😀
I didn't modify motherboard, only CPU. What RAM You have? How much did You overclock your sytem? Why you running CPU on 1.6V, mine is running on FSB 133 on 1.45V.
Reply 4 of 15, by tomoa
firage wrote:
Same combo here, quite nice. Don't you just hate that "Tualeron" CPU ID string, though?
Yes, I do, maybe i will edit the bios and write the proper name of processor.
Reply 5 of 15, by melbar
Seems that your Geforce 5900XT@5950ultra has no problems with the oc'ed 93.46MHz AGP speed 🤣
Is that cooler on the Geforce from Zalman? The fan isn't original right?! How noisy it is (the rpm with this little blades)?
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 6 of 15, by tomoa
Geforce Gainward FX 5900XT@5950 Ultra works ok on FSB 140 na CUBX, FSB 150 works in 3Dmark 2001 SE but with artifacts and hangs. I don't know the cooler name, i bought the card used.
    29.52 KiB
Reply 7 of 15, by tomoa
Yesterday I mounted Infineon 256 MB PC133 CL2, but motherboard Asus CUBX-E 1.01 set the memory on 2-2-2-8. The memory does not work on this settings, I had to manually set memory on 2-2-2-32, and then works well.
When was used one memory slot only system works on FSB 150 with times 3-3-3-32, on FSB 140 with times 2-2-2-32, on FSB 133 with times 2-2-2-32. After I put four memory bones, system works well only on max FSB 124, on FSB 133 hangs even on times 3-3-3-32.
Benchmark: Futuremark 3DMark 2001SE default settings - 9274 score (4 x Infineon 256 MB PC133 CL2)
    414.27 KiB
    2.54 MiB
    2.66 MiB
Reply 8 of 15, by Imperious
Try an earlier driver if possible. The scores are a bit on the low side.
Reply 9 of 15, by tomoa
I think, it is not so bad, I go on AGP x2 not x8, it is a big deference.
My 3DMark01 Mega Thread
Jade Falcon wrote:
just a quick unoptimized 3d01 run with stock setting and a 100mhz cpu OC. https://s9.postimg.org/65kl32zq5/untitled.jpg […]
havli wrote:
10k barrier with PIII Coppermine beaten :D […]
10k barrier with PIII Coppermine beaten 😁
PIII 933 @ 1297 MHz
Asus TUSL2
GF 6800 GT @ 425/1100
256MB PC133 CL2 (Infineon)
Win XP SP3
10 008 points
Reply 10 of 15, by Roman78
I must be a Zalman clone. Original has Zalman written on the blades and on the holder.
Reply 11 of 15, by Phreeze
has anyone used this with a Pentium 3 1000Mhz ? jumperless, it detects it only as a 7.5 x 100 Mhz = 750Mhz cpu. With jumpers set to 7.5 x 133 (agp 2/3), i get to the screen with the gfx bios but not the mainboard POST
ArGUS Parts list: http://bit.ly/2Ddf89V
Reply 12 of 15, by PC Hoarder Patrol
A thread necro I know, but it looks very much like a NorthQ NQ-3860, but with a replacement fan
692.26 KiB
NorthQ NQ-3860 (pics from TWEAK.DK)
Reply 14 of 15, by D3FEKT
okenido wrote:
I get around 5600 points with a PIII 933 and a Radeon 9550 on via 133A chipset. I though I was completely CPU limited ?
It's your Radeon probably limiting, my P3 1000 coppermine, 1.5gb ram, 6800 XT 256mb on 133a chipset epox board hits tad under 9500 points..
