First post, by TV5Fun
Hello,
I'm trying to get the Steam version of TIE Fighter Collector's CD-ROM running with a joystick. For reasons unknown, TIE Fighter looks for a Joystick on axes 3 and 4, but I've managed to use the control mapper to fix that. The problem I'm having now is that the game appears to detect and calibrate the joystick just fine. It works perfectly well in the menu screens to move the cursor around, but as soon as I get into flight, the joystick goes haywire. It immediately starts off to a far corner, and while moving the joystick seems to have a small effect, I can't get any actual control out of it. I've tried hitting alt-C to calibrate in flight, but that doesn't fix the issue. I've also tried setting timed=true and timed=false and gotten the same results. Here's the config I'm using:
# frameskip: How many frames DOSBox skips before drawing one.# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.# scaler: Scaler used to enlarge/enhance low resolution modes.# If 'forced' is appended, then the scaler will be used even if the result might not be desired.# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.frameskip=0aspect=truescaler=advmame3x[cpu]# core: CPU Core used in emulation. auto will switch to dynamic if available and appropriate.# Possible values: auto, dynamic, normal, simple.# cputype: CPU Type used in emulation. auto is the fastest choice.# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.# cycles: Amount of instructions DOSBox tries to emulate each millisecond.# Setting this value too high results in sound dropouts and lags.# Cycles can be set in 3 ways:# 'auto' tries to guess what a game needs.# It usually works, but can fail for certain games.# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.# (Example: fixed 4000).# 'max' will allocate as much cycles as your computer is able to handle.## Possible values: auto, fixed, max.# cycleup: Amount of cycles to decrease/increase with keycombo.(CTRL-F11/CTRL-F12)# cycledown: Setting it lower than 100 will be a percentage.core=autocputype=autocycles=autocycleup=1000cycledown=1000[mixer]# nosound: Enable silent mode, sound is still emulated though.# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.# Possible values: 1024, 2048, 4096, 8192, 512, 256.# prebuffer: How many milliseconds of data to keep on top of the blocksize.nosound=falserate=49716blocksize=1024prebuffer=80[midi]# mpu401: Type of MPU-401 to emulate.# Possible values: intelligent, uart, none.# mididevice: Device that will receive the MIDI data from MPU-401.# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.# See the README/Manual for more details.mpu401=intelligentmididevice=defaultmidiconfig=2
[sblaster]# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.# sbbase: The IO address of the soundblaster.# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.# irq: The IRQ number of the soundblaster.# Possible values: 7, 5, 3, 9, 10, 11, 12.# dma: The DMA number of the soundblaster.# Possible values: 1, 5, 0, 3, 6, 7.# hdma: The High DMA number of the soundblaster.# Possible values: 1, 5, 0, 3, 6, 7.# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.# Possible values: auto, cms, opl2, dualopl2, opl3, none.# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).# Possible values: default, compat, fast.# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.sbtype=sb16sbbase=220irq=7dma=1hdma=5sbmixer=trueoplmode=autooplemu=compatoplrate=49716[gus]# gus: Enable the Gravis Ultrasound emulation.# gusrate: Sample rate of Ultrasound emulation.# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.# gusbase: The IO base address of the Gravis Ultrasound.# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.# gusirq: The IRQ number of the Gravis Ultrasound.# Possible values: 5, 3, 7, 9, 10, 11, 12.# gusdma: The DMA channel of the Gravis Ultrasound.# Possible values: 3, 0, 1, 5, 6, 7.# ultradir: Path to Ultrasound directory. In this directory# there should be a MIDI directory that contains# the patch files for GUS playback. Patch sets used# with Timidity should work fine.gus=falsegusrate=44100gusbase=240gusirq=5gusdma=3ultradir=C:\ULTRASND[speaker]# pcspeaker: Enable PC-Speaker emulation.# pcrate: Sample rate of the PC-Speaker sound generation.# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.# Possible values: auto, on, off.# tandyrate: Sample rate of the Tandy 3-Voice generation.# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).pcspeaker=truepcrate=44100tandy=autotandyrate=44100disney=true[joystick]# joysticktype: Type of joystick to emulate: auto (default), none,# 2axis (supports two joysticks),# 4axis (supports one joystick, first joystick used),# 4axis_2 (supports one joystick, second joystick used),# fcs (Thrustmaster), ch (CH Flightstick).# none disables joystick emulation.# auto chooses emulation depending on real joystick(s).# (Remember to reset dosbox's mapperfile if you saved it earlier)# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).# autofire: continuously fires as long as you keep the button pressed.# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.# buttonwrap: enable button wrapping at the number of emulated buttons.joysticktype=4axistimed=trueautofire=falseswap34=falsebuttonwrap=false[serial]# serial1: set type of device connected to com port.# Can be disabled, dummy, modem, nullmodem, directserial.# Additional parameters must be in the same line in the form of# parameter:value. Parameter for all types is irq (optional).# for directserial: realport (required), rxdelay (optional).# (realport:COM1 realport:ttyS0).# for modem: listenport (optional).# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,# transparent, port, inhsocket (all optional).# Example: serial1=modem listenport:5000# Possible values: dummy, disabled, modem, nullmodem, directserial.# serial2: see serial1# Possible values: dummy, disabled, modem, nullmodem, directserial.# serial3: see serial1# Possible values: dummy, disabled, modem, nullmodem, directserial.# serial4: see serial1# Possible values: dummy, disabled, modem, nullmodem, directserial.serial1=dummyserial2=dummyserial3=disabledserial4=disabled[dos]# xms: Enable XMS support.# ems: Enable EMS support.# umb: Enable UMB support.# keyboardlayout: Language code of the keyboard layout (or none).xms=trueems=trueumb=truekeyboardlayout=auto
Has anyone else seen anything like this before?
