First post, by Nilex
Trying to figure out something:
Game's setup program only allows setting ONE Sound Card (so no SB/MIDI combo). It's a damn shame because with SB you get nice SFX & Speech (and shitty music) while General MIDI provides pretty good music. I all but gave up trying to set up both but before that I though to give this board a shoot. Tried SB with 330 port to trick it but it's too smart for that. SETUP/SOUND.CFGs are gibberish to me but perhaps hold the key to this. Any ideas or should I just drop it?
Game is CD-ROM version, not Floppy.
    225.96 KiB
    two setup screens
Reply 2 of 5, by Nilex
Roger. Thank you for giving it a nice title. Better that I would have thought of, for sure.
Meanwhile, I found that Dune II had the exact same limitation so Westwood released an unofficial patch to support two sound card combo called Multiple Sound Device Patch. Link leads to a small archive which contains README and few setup files to replace the originals.
Mentioning it in case passing hobbyist traveler gets inspired to produce a hack for HST. Maybe it also helps lucky few who weren't aware.
My hope lives... 😀
Reply 3 of 5, by Osprey
I got it working. It ended up being extremely simple. Go into the DRIVERS folder, rename SBPRO2.MDI to something else, make a copy of MPU401.MDI and rename that copy to SBPRO2.MDI. Select "Sound Blaster Pro 16" in the setup program and give it the usual (ex. 220/7/1). The SB16 setting uses the MIDI driver for the SBPro II.
Reply 4 of 5, by Nilex
Am I glad to have met you 😀 It works! Simple but effective. Thank you!!
Though to share this icon I made for my DOSBox launch shortcut couple of days ago.
I like em simple and recognizable off the bat. This is Fluyt's steering wheel.
Preview (full size):
    HST.ico.zip
    1.77 KiB
    21 downloads
Reply 5 of 5, by Osprey
Thanks for the icon. I make my own personal installers for a lot of games, especially DOS games and ones that I've set up a particular way, so I'll probably use that.
Edit: To put the solution where more people might find it, I've created a page at PCGamingWiki for the game: https://pcgamingwiki.com/wiki/High_Seas_Trader
