First post, by fitzpatr
Hi, everyone,
I just received a CT1740 (059334) from eBay. Unfortunately, there appears to be some damage to a few components. Specifically, capacitor C15 only has two thin metal plates on the leads, and capacitor C11 is missing. I only really bought it for the removable, albeit fairly useless, CT 1748A CSP in the socket. Nevertheless, I'd like to repair this card. There are also a few exposed traces (the protecting layer is gone, bare copper is visible, but the traces appear intact.
I would appreciate some assistance from my fellow VOGONSers! What I need is:
What are the specifications of Caps C11 and C15?
What can I coat the exposed traces with to protect them?
This is the image which I'm using as reference. It is the same revision.
1.02 MiB
Reference CT1740
This is my card:
357.75 KiB
CT1740 with Damage
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 1 of 10, by Jo22
Hi, just checked the caps on my CT1740..
C11 = 4.7uF (50v)
C15 = 100uF (16v)
PS: I also attached a photograph.
Unfortunately, my cameras can't take close-up photos.
    261.57 KiB
Reply 2 of 10, by fitzpatr
Thank you very much, Jo22. That is very helpful.
486 Build
Reply 3 of 10, by 133MHz
Clear nail polish would be fine for that. 😀
http://133FSB.wordpress.com
Reply 4 of 10, by gdjacobs
A spray bomb of conformal coating is perfect, if you've got an electronics place near enough to you.
Reply 5 of 10, by fitzpatr
That was my first thought.
I will attempt to acquire some locally. Thank you for the advice.
486 Build
Reply 6 of 10, by kixs
It seems my CT1740 also has some problems... The volume wheel doesn't do anything. Where to start checking?
This is the card:
Any help welcome 😀
Reply 7 of 10, by derSammler
Change the two jumpers left from the speaker jack from line out to speaker out. 😉
Reply 8 of 10, by kixs
Thanks! All good now 😁
Now I have to find out what is wrong with CT3910 with playing only on one channel on Speaker out, line out is fine. And with CT3670 that also plays on one channel but on both speaker and line out 🙁
Reply 9 of 10, by fitzpatr
Have you gone into the mixer utility?
486 Build
Reply 10 of 10, by kixs
I guess it was a false alarm 😊
In this setup I had mixer set in autoexec.bat and it seems both 3670 and 3910 work fine. Noob 🤣
