First post, by Batyra
Hi,
I desperately need BIOS for my Diamond Edge 3D 2120...
Please HELP.
Reply 1 of 13, by vetz
A quick Google search on this forum should've provided you with what you need:
Dead BIOS chip on Edge3D 2200
Reply 3 of 13, by fitzpatr
Batyra wrote:
Thank you!
that 2200 and unactive dopbox link fooled me.
Great thanks!
37.12 KiB
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 4 of 13, by Batyra
fitzpatr wrote:
Batyra wrote:
Thank you!
Great thanks!
Hehehe... but acually that was not sarcasm at all 😁 seriously.
That link really heled me - I missed it because of its title...
Reply 5 of 13, by vetz
Yes, the dropbox link is dead, but the file is luckily attached to the same post.
BIOS works for both 2120 and 2200 (says 2000 series in the file).
Reply 6 of 13, by Batyra
Yes exactly and I was told that this was a case and my Edge 3D should be working again... Unfortunately I don't have bios flashing tools or skills...
Reply 7 of 13, by moturimi1
So do you need help? Do you want me to flash it for you and provide the flashed EEPROM to you?
I have a 2120 card.
Reply 8 of 13, by meljor
Are there any software tools to flash it? Maybe by using another pci graphics card?
I have the same problem here: a 2200 card and it doesn't even have the bios chip anymore so i need to flash another one.
Reply 9 of 13, by moturimi1
As mentioned. I have EEPROMS and can flash them.
Reply 10 of 13, by meljor
I know, thank you, but that was not the question.
Reply 11 of 13, by vetz
Afaik, no, you need an EEPROM flasher. i had help from Keropi here on vogons 😀
Reply 12 of 13, by gdjacobs
This can also be done with flashrom and any supported network card (featuring a PDIP BOOT ROM socket).
https://www.flashrom.org/Flashrom
https://www.flashrom.org/Supported_hardware#PCI_Devices
Reply 13 of 13, by meljor
Thanx, i will look into that and see how it goes!
