First post, by andreja6
So I have a Windows 98SE PC with an AB-BH6 Motherboard which has the Intel 440BX chipset.
Currently, the PC has a 16mb 3DFX VooDoo3 GPU, and even though i like it a lot i really want to try some DX9 games for windows 98.
However, I have heard of some limitations, such as 64MB aperture size. I'm not sure where i read this exactly, but i know it was on some Wikipedia article, does this mean I cannot use AGP cards with more than 64 megs of ram?
What AGP card would you recommend for this?
Also, in the AB-BH6 manual, it clearly states that 768MB SDRAM is supported, however in all documentation about the 440BX Chipset, it only supports 512MB on SDRAM and 1GB EDO RAM, however the motherboard does not support EDO RAM?
I am a bit lost with this machine, It's documentation is plentiful but contradictory...
it even states "[768MB] is the maximum memory size the Intel® 440BX chipset supports it, also depends on the size of
memory module you can buy on the market."
Yes it also put the comma in the wrong place
The PC currently has:
128MB SDRAM PC100
Pentium II-400Mhz 512k Cache 100Mhz FSB
5 PCI slots - Sound Blaster Live! - SMC Lan card
2 ISA Slots - Winmodem (Oh lord it is horrible)
1 2x AGP Slot - 16MB 3DFX VooDoo 3 GPU
Reply 1 of 17, by Deksor
I don't think the AGP aperture size is a problem, iirc that's just if your gpu has no more free memory, it can store stuff in the main memory and this is the maximum size you can reserve.
Your biggest problem will be the 2x 3.3v agp slot, not the aperture size. There are 2 kinds of AGP cards : 3.3v and 1.5 cards which are keyed and one won't fit in the other. Though there are several universal cards (those which have 2 notches)
I'm not sure if a pentium 2 400MHz will be great for DX9 games, that computer is perfect for windows 9x games, but not really for things newer, even if you upgrade it as far as it can go, you should be considering buying a pentium 4 or an athlon 64 for such thing instead
Reply 2 of 17, by andreja6
I know the pentium 2 will not be great for DX9, I just really wanna try messing around with the PC. It's a slot 1 machine so you can't really upgrade it to anything further than a pentium III, but i honestly love the weird limitations of the Pentium II 400MHz
What i don't love is the blown up PS/2 ports. Why would a mouse accidentally placed in the wrong port blow it up
Reply 3 of 17, by chinny22
As Deksor said its the 2x AGP that's the limiting factor not memory.
Ti4600 from Nvidia camp or Radeon 9700 Pro from ATI are the final 3.3v and therefore work no problems, both are 128MB
Of course both of these are total overkill for a P2 but gives you an idea how far up the graphics food chain you can go.
A good page on BX motherboard is here, but basically it comes down to not all 256MB sticks or greater will work and outdated documentation.
http://homepage.hispeed.ch/rscheidegger/ram_bx_faq.html
Reply 4 of 17, by idspispopd
I don't know if that would blow up the port, I thought that just wouldn't work. What does damage PS/2 ports is hot-plugging, they are just not designed for that. (Has that experience myself.)
Reply 5 of 17, by Adrian_
chinny22 wrote:
As Deksor said its the 2x AGP that's the limiting factor not memory. Ti4600 from Nvidia camp or Radeon 9700 Pro from ATI are the […]
There are some R360 cards (including 9800Pro) that have both keys on the slot. These were made by some of the major Chinese OEM manufacturers and are indeed the last ones usable on Bx based boards.
However, unless using a modded Bx with a top-end Tualatin, the difference between the R350 and the R360 cards should be irrelevant.
Reply 6 of 17, by dexvx
Ironically, I never knew that you couldn't hotplug PS/2 ports. I used to do that all the time back in the day and didn't seem to have a problem. Nowadays I'm much more careful.
Just out of curiosity, is there a way to revive the PS/2 port?
For DX9, I'd just get a Radeon 9600, 9700 vanilla or Fire X1/Z1 variant. They are plentiful and cheap (Z1 for less than $10 US shipped).
Otherwise you could go for a FX 5700 or the Quadro variant for cheap.
Reply 7 of 17, by yawetaG
If you could enter the BIOS and enable the USB legacy option, you could use a USB keyboard instead of PS/2 (obviously if the option isn't enabled by default, you need a working PS/2 keyboard...).
Single-sided 256 Mb sticks likely won't work, or will be detected at half their capacity.
DX9 games can work, depending on the game (RTS games certainly do). Just get a DX9 compatible AGP card that fits (Asus TNT Riva with 32 Mb RAM does).
Reply 8 of 17, by LSS10999
AGP cards can be a bit tricky with 440BX chipsets given its slot being 3.3V and potential issues between AGP Aperture Size and ACPI implementation.
Up to GeForce 6200, or some 6600 with the 3.3V key will work with the 440BX, and it's possibly the best you can get (they are the first ones to support DirectX 9.0c). However, with some boards (like my old FIC VB601), you may need to set AGP Aperture Size to 32MB or less in order to get it functional under Windows, as with larger AGP Aperture Size, the video card drivers might complain about some memory range conflicts with the ACPI, and refuse to function.
However, this depends on what types of programs you intend to use with the 440BX build. Back then I did some benchmarks with a 6200 and some FX-series cards (like FX 5200 and 5600), I found that, against the earlier generation (FX-series), 6200 performs better in tests using DirectX 9, while worse in tests using earlier versions of DirectX.
Reply 9 of 17, by TheAbandonwareGuy
I've seen one single 7800GS that was 3.3 keyed on eBay and several 6800s that were. The 7800GS may have been an ES, I'm not sure.
Reply 10 of 17, by The Serpent Rider
Galaxy 7900GS is keyed as universal AGP, but very hard to find. Quite easy to find is 6600GT with universal AGP (Sparkle, Galaxy, BFG). Also ASUS GeForce 6800GT/6800GE are electrically compatible with 3.3v boards, but not physically. Fortunately can be reworked (if you dare) and not that hard find. Unfortunately all listed cards has driver issues with 440BX boards.
Reply 11 of 17, by Radical Vision
Nonsense i have Gigabyte BX2000 board, it not shine with great CPU support, but it have BX440 chipset and it have x4 memory slots, and it can run 1GB of memory no problem.. So you just need to find bigger size modules, not sure if the BX440 supports sticks of 512MB on module, i have here some and i think most motherboards with BX440 did support 512MB on one stick memory, but need to test that don`t remember if i did test or not, but i think i did, and it was working.
For the AGP card you just need card that have x2 chops on the connector, the first is for the old AGP slots that are 3.3v, and the new one that is for 1.5v AGP.
32.6 KiB
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 12 of 17, by blacksn
Thanks, tried to start 6600 with p-iii 500 and 440bx. Your advice set agp aperture size to 4Mb helps me to run windows.
AMD Am5x86-133ADW/Shuttle HOT-433 256Kb/4x16 SIMM EDO/ATI Rage XL 8Mb/Ultra100 TX2/WD 400BB-60DGA 40 Gb/Opti 82c861 USB/ESS1868/RTL8139/CD-ROM NEC CD-3002a
Reply 14 of 17, by Windows9566
a Geforce 2 MX 400 worked fine in my ASUS P2B, same with a Geforce 3 TI 500 and a Geforce FX 5200.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 15 of 17, by blacksn
I cant run 3D Mark 99 with 6600. With MX440 - no problem.
Reply 16 of 17, by blacksn
I have changed speed of Intel P-III 500 CPU from 5x100 to 5x66 and 6600 works fine with AGP Aperture 64 Mb and 3D Mark 99 runs fine. I will try different BIOS versions to solve this issue.
Reply 17 of 17, by iraklis777
I have a slot 1 intel bx 440 motherboard With a pentium 2 400mhz. I tested 3 graphics cards 2 agp 3.3v ( a riva tnt and a geforce 2 ti) , and a pci card , (a matrox milenium g450) the results are the following :
matrox and riva tnt very close together with riva ahead , and geforce 2 ti at the top but.... With a very narrow margin to tnt. The 2x agp compine with p2 400mhz gave a huge bottleneck to gf2 ti.
I hope my test been usefull
