First post, by GiSWiG
So the card does not have a manufacuter stamped anywhere. The only identifiable marks are CGTS2 ver1.0 and 64M.
The chip is marked gforce2GTS Pro.
The memory is Samsung. Most screenshots of geforce2GTS card seem to not use Samsung.
It has 64MB of memory.
On boot, it shows as a Geforce2 Pro VGA BIOS.
I used TechPowerUp GPU-Z which really just states it is an NVIDIA GeForce2 GTS/GeForce2 Pro
The memory clock throws me off a bit. According to GPU-Z it is ~180MHz (DDR). From what I've seen, a GTS is 166MHz and a GTS Pro runs at 200MHz. Modern cards throttle memory speed but I don't think older cards did. I'm wondering it this card does and boost up to 200 when gaming (I'll test that later).
From what little information I can find, it might be a PowerColor. I cannot find any reviews that covered PowerColor. What screenshots I have found are fuzzy or don't fully show the card. Also, unless the memory does throttle, I'm thinking it is either a overclocked GF2 GTS or an underclocked GF2 GTS Pro.
I've attached some screenshots.
Thanks for any help!
94.8 KiB
40.27 KiB
2.06 MiB
2.09 MiB
2.57 MiB
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
Reply 1 of 7, by GiSWiG
(just needed two more files)
2.61 MiB
2.46 MiB
Reply 3 of 7, by Scali
I have a GF2GTS as well, and the control panel allows you to change GPU and memory speeds on-the-fly (you need to install the NV 'Coolbits' registry patch to enable this). So theoretically it could throttle, but afaik the driver did not do this.
It does have separate 2D and 3D settings though, iirc.
However, you can reprogram the BIOS to custom GPU and memory speeds, so it could be that this is some kind of OEM model with lower clocked memory.
Reply 4 of 7, by meljor
Yeah it is a weird one. It is a real gts/pro as it sits right in the middle when it comes to memory speed and clockspeeds of the gpu are 200mhz for both and they both use the gts core.
It says pro at post and it has a stamp on the pcb that says ''pro'' so it is at best a downclocked pro 🤣
Reply 6 of 7, by GiSWiG
kanecvr wrote:
It's either a Inno3D or Leadtek GF2 GTS for OEMs.
From what I did find, anything Inno3D had Inno3D stamped in the upper-right corner. The Inno3D's have the same separate PCB for the S-Video port. Leadtek's seem to have a completely different style cooler on its GTS/Pro variants, most where the fan is not directly over the chip.
I think it is a PowerColor. I found a listing on electromyne's website. It doesn't have any specs listed:
http://www.electromyne.de/Graphics-Cards-AGP- … ---B-Stock.html
Reply 7 of 7, by kanecvr
Leadtek had lots of fan designs installed on their GTS/PRO line - 3 types to be precise. And the only GTS with 366MHz (183 DDR) ram I know of is OEM Leadtek used by some east european PC builders back in the day.
