First post, by tabm0de
Back again with a question for any one that might know regarding the different Compaq Presario motherboards.
So i am aware of two different models, one with modem and one that has built in cpu ( if im not wrong only the first models did have that ).
Myself i have one with out builtin modem or cpu but i have a connector which i dont know what it is for, there isnt any info on http://th99.classic-computing.de/src/m/C-D/32243.htm so thats no help.
Here is a image with the modem built in:
Here is one of mine which i have the exact copy of with following connection:
B1vthCh_d.jpg?maxwidth=640&shape=thumb&fidelity=medium
naa, nothing yet...
Reply 2 of 9, by delinthe
I'm fairly certain that is an 80 pin SCA connector. They're commonly used for SCSI drives. I'll have to open my 425 and see if I have one as well. I've seen some boards that have an unpopulated pin header in that location.
Reply 3 of 9, by delinthe
The top drive has an 80 pin SCA connector so you can compare. I'm not entirely certain what it would be used for in this system however. I don't believe there is a SCSI controller on the motherboard.
    140.17 KiB
    https://commons.wikimedia.org/wiki/File:SCSIHardDriveConnectors.jpg
Reply 4 of 9, by perhenden
Is it possible it's for added cache? I got a similar slot on a socket 7 motherboard that adds cache to the motherboard.
I have a Presario 425 with this slot as well and would love to discover what its purpose is!
    1.46 MiB
    Here's a bit zoomed in image of the slot
Reply 5 of 9, by delinthe
Still not sure what the slot is for but my 425 motherboard doesn't have one, it only has the pads. I took a look at the traces going to the pads and they seem to run to the daughterboard connector, some LS374 chips near by which are flip-flops, and a few run over to the BIOS. If I had to take a guess I'd say it's for some type of expansion module running on the ISA bus.
    1.75 MiB
Reply 6 of 9, by perhenden
The only relevant thing I find in the parts manual is "6260 SCSI-2 Controller Board ", other than the modem, which I thought was somewhere else (my board doesn't have the modem).
Maybe the SCSI board makes sense, perhaps this consumer market motherboard model was shared with a business model, Prolinea?
Reply 7 of 9, by tabm0de
I dont thing it was ever used on presario 4xx, but it seams to be used with compaq prolinea net1/xxs, which the network card is connected to, so i guess its uses the SCA connector but for some type of home made isa slot.
I have been trying to get the network card working on that board without any luck, but i havnt stopped yet to try, someday i will have more time 😉
naa, nothing yet...
Reply 8 of 9, by pampilhoso
I have the compaq presario cds 520, and that slot is used for plugging in the modem. Here is a photo of the one I have:
113.57 KiB
The models that dont come with the soldered interface already have an onboard modem, and the ones that have it will also have a metal braket slot for the modem at the back of the computer.
Reply 9 of 9, by tabm0de
Cool, here is the prolinea card which i havnt got working on my presario.
    1.05 MiB
naa, nothing yet...
