486 system freezes
First post, by Zeecor
Hi!
I just completed my 486 build but the system freezes at random times. If I wiggle any of the ISA cards slightly it starts working again. At first it was the NIC so I removed it but after that it's the sound card and after that it's the graphics card or the IDE/floppy controller. I have cleaned all the ISA slots with IPA and a toothbrush so it should be clean. Has anyone has this issue before and know how to fix it?
My parts:
Motherboard: Dataexpert EXP4044 V1.0
CPU: AMD 5x86 133
PSU: Sunshine 200W AT recapped
IDE/floppy controller: Pine PT-626 VLB
GPU: Cirrus Logic 5428 1MB VLB
Sound card: Yamaha YMF719E-S
NIC: 3com 3C509B
I also got a 1GB CF card as HDD, a CD-ROM and a 1.44MB floppy drive.
Thanks!
Reply 1 of 7, by BitWrangler
Flip the board and look for dry solder joints on the back of the slots.
Reply 2 of 7, by bjwil1991
I was about to post that, and I believe that is common on boards for the solder points to either dry up or crack, which requires a re-flow of the solder. Luckily, my Packard Bell still runs, but takes a while for it to turn on since I'm using 2x AA batteries for the CMOS settings (the old battery was a soldered on BR1225), but I can solder on a battery holder for a lithium battery, but I need a de-soldering iron.
Reply 3 of 7, by Frasco
My 386SX/33 board had similar problems.
I ended reflowing the AT power connector (I just flippled the motherboard and used an soldering iron on terminals)
The attachment AT power.JPG is no longer available
Man, 12V was 3V or less and -12V was 0V or -12v on rare occasions. What a mess...
Reply 4 of 7, by Ampera
I actually have an EXP-4045. Great board. I had a stupid issue where a metal standoff I forgot to remove (and another one I couldn't remove) shorted out traces on the board and refused to let it post. Man was that an annoying problem.
Reply 5 of 7, by Zeecor
Thank for all the tips! I switched places on the IDE controller and GPU and it has been stable this far. I will take a look at reflowing if the problem comes back.
Reply 6 of 7, by GPA
no need for a de-soldering iron, you can buy a cheap pump, like this one:
http://www.ebay.co.uk/itm/New-Metal-Desolderi … WEAAOSwHHFY-e1c
works ok for occasional work. Just make sure to add some fresh solder to the joint before pumping, it will go way smoother.
Reply 7 of 7, by Frasco
I'm not quite sure I'm on topic...but hey, if you want to be sure before doing something, you are not doing much at all. 😎
- Ok , to hell with cheap lectures and advices -
I'll be using the external battery header and a speaker wire on this one and I'm looking for a elegant solution:
The attachment M321.jpg is no longer available
Funny how the distance from positive and negative barrel battery terminals just match the battery holder.
Are they deactivated right now? In other words, can I install the holder where the barrel battery lays without "overvolting" something?
May I proceed ?
And although I tried to neutralize PC Chips fans with disdain earlier in "PC Chips sucks" thread, holding this intact ancient artifact feels more powerful than having the ultra hyper ultimate GTX or Titan from Nvidia. Furthermore, you wouldn't believe how much people are asking for a XT, 286 or 386 board around here...
