First post, by dnewhous
First off, thank you Dosbox for liberating me. You have brought light where before there was only darkness.
Is there anyway I can get Dosbox to run the same "mount" command everytime I run it?
If I increase the sampling rate for soundblaster emulation, do I need to increase the block size as well? Would it improve the sound quality anyway?
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Yes, you can either use command line parameters of DOSBOX or to add it to DOSBOX.CONF. See README and DOSBOX.CONF for details.
Mirek
