First post, by arteq
Hi Vogons Friends
I need your help to identify my MB.
Could you please help me to get bios , chips or any info about this MB.
Thank you in advance as always.
Best regards
arteq
    1.02 MiB
Some items for sale 😀
https://docs.google.com/spreadsheets/d/1YNG8R … dit?usp=sharing
Reply 1 of 3, by Predator99
Interesting board 😉
There are numbers in the sockets, I can see 8087 (Coproz)and 27256 (Bios). Can you read the others?
Others might be
8259 Programmable Interrupt Controllers
8237 Direct Memory Access Controller
8254 Programmable Interval Timer
8042 keyboard controller
DS12887A RTC
You can try this BIOS after you have all Chips together 😉
http://www.phatcode.net/downloads.php?id=101
Should work.
Reply 2 of 3, by Anonymous Coward
I am pretty sure this board is a Juko ST.
You will need the other chips (which are obtainable) as mentioned above.
Reply 3 of 3, by 133MHz
It does look like a Juko indeed, but it seems that you'll also need new crystal oscillators along with all the chips that have been cannibalized.
http://133FSB.wordpress.com
