First post, by GodOfCows
GodOfCows
Offline
Note: First post so sorry if I do something wrong
Problem: The Appstore has a good port of Dosbox but because of apple the person that published it has disabled filesharing to the application. This is easily (not really) fixed with jailbreak but I really don't want to do that (not even sure if my device is capable)
Question: The IPX server emulator is actually not disabled on the dos port and can be used (I tested it with hosting a doom multiplayer game and worked perfectly with four players). My Question is, is there a application for ms-dos/Dosbox that can send files to another computer on the IPX server affectively bypassing the need for filesharing to be turned on?
Any feedback is good! Negative or Positive 😁
