First post, by Jade Falcon
Looks like UT99 in windows 3.1 or something.
windows 3.1 mode in windows 4?
I would think something like that could easily be mocked up by someone who knows how to digitally edit. That seems more likely than someone getting UT99 to run in Win3.1. Although, I did find this:
https://www.youtube.com/watch?v=kPy1XKq0Dog
Yep, that's probably UT running under Windows NT 3.51, you can totally do it 😀.
I know it runs in NT 4.0, but full screen only in software mode. OpenGL does not work, and DirectX only works in a window.
"AI Requires Proof That You Are Human"
Interesting. Thanks guys
Windows NT 3.51 is very powerful, i have tinkering with it a lot, if you tweak it enough, it is basically NT 4 with the good old 3.1 interface.
And you can have even some Windows 2000 capabilities.
Windows 3.1x is a limited 16bit system, with some 32bit capabilities(Win32s) and it definetly does not run Unreal Tournament, so it is fake!
You can see in FIle Manger it says C:\ - NT (most likely NTFS), proving it is indeed Windows NT 3.x
All these people here and none satisfied OP request yet
^ finally!
hahahahahahahaha
wrote:Windows NT 3.51 is very powerful... it is basically NT 4 with the good old 3.1 interface...
Although I think that it may be NT3.51, keep in mind that Windows 9x have a line in win.ini that allows the user to change the shell (and I remember that it includes progman.exe and fileman.exe like Windows 3.x). It does not affect the UI elements (i.e.: maximixe/minimize icons, windows borders), but it wouldn't be too dificult to make a Windows 95 computer mimic Windows 3.x environment.
I'm pretty sure there were 3rd party extensions that did it completely.
wrote:^ finally!
Yes thanks. but can you remove the legs?
Just remember we're counting on you.
Unreal engine was developed in Windows NT 3.51, it makes sense UT99 would run under it.
― Κυνικός Δράκων
