First post, by fsmith2003
I am trying to decide what I should get for a 1992 era specific machine. A Cirrus Logic-GD5424 VLB or a Tseng 4000AX ISA? The 4000AX had been out since 1989 but I hear it held its own until the 3D accelerator days. But it is only ISA where the GD5424 is VLB. Have any of you ever compared the two to see which has the edge?
Reply 2 of 10, by fsmith2003
And am I correct in saying there was no version of the Tseng 4000AX in VLB?
Reply 5 of 10, by fsmith2003
kixs wrote:
There were ET4000AX on VLB. I have one.
Would that provide a performance bump then on VLB vs ISA? Wonder if there are comparisons of both the GD5424 and 4000AX VLB versions then?
Reply 6 of 10, by keropi
I would chose the CL card because it's more compatible... Both cards in vlb form will be faster than their isa counterparts
Reply 7 of 10, by kixs
Take a look (I did these benchmarks a few years ago and are unfinished - will redo everything and add more cards... sometime...):
I'd guess the performance of VLB 5424 and ET4000 are on par in DOS. In Windows 5424 has GUI accelerator while ET4000 doesn't - you need /w32, i or p models. w32p is on par with S3 864 in DOS, but lags in Windows.
Reply 8 of 10, by badmojo
+1 on this - I'm a big fan of the ET4000AX chipset but the VLB versions I have (2 of) are a bit finicky. Ultima 7 for example doesn't work. The ISA versions of that chipset I've tried are more compatible for whatever reason. Ultima 7 works with ISA - in the same PC that I tested the VLB cards.
CL cards on the other hand seem to be consistently very good and very compatible - some have better image quality than others because of the implementation.
Reply 9 of 10, by Scali
Yea, getting brand name cards may help. I have a Diamond Speedstar Pro VLB, which seems to have reasonable image quality.
Reply 10 of 10, by badmojo
Yes those old Speedstars were gorgeous - I have a WDC based ISA that is a wonder to behold.
