First post, by Obiwan
Hi!
I've got an old MT-32 that I plugged to my Roland SCC1 (IRQ 2 and MPU 330h-331h). When I start X-wing or Legend of Kyrandia (for example), the music plays through both devices (I can check that because I use an external mixer and can shut off 1 output). Then there is a hanging note (on the SCC1 channel). Besides X-wing plays some others instruments instead of the regular set. Legend of Kyrandia just crashs after introduction.
The Roland MT-32 works fine. I checked that before: it used to work fine on a Sound Blaster 16 (still in place in the very same computer). Basically I just changed the MPU interface from the Sound Blaster 16 to the Roland SCC1.
Is there someone to have a clue? 😕 thanks.
Reply 1 of 10, by jesolo
You will have to provide a bit more information.
What are your System specifications
Type of sound card being used (model number).
How are you connecting the MT-32 to your SCC-1? Via the MIDI thru connector on the back?
Did you disable your Sound Blaster MPU-401 MIDI port or, at least change the address and IRQ of the Sound Blaster's MPU-401 interface?
Also, if you intend of playing a General MIDI game, then you must use the SCC-1 and specify General MIDI (or Roland Sound Canvas) in your game's setup menu.
If you are using an older game (from the 1987 to 1992 era), then you must select Roland MT-32 and use the MT-32 for music playback.
Reply 2 of 10, by keropi
what kind of system are you using? maybe ACPI is using IRQ2 and it causes issues
Reply 3 of 10, by Obiwan
Thanks for your quick replies.
My configuration is:
Pentium 90, 16 Mo RAM, BIOS Award with parallel port disabled
DOS 6.2, multiple menus at start (EMS or XMS)
Graphic adaptator: Miro 12 PD 1 Mo
I installed several sound cards:
Sound Blaster 16 (CT 2230), IRQ 5, I/O 220, DMA 1, HDMA 7, MPU disabled, IDE Port Disabled, Joystick Port Enabled)
Roland SCC1, IRQ 2, MPU adress 330-331h
Roland MT-32, plugged to the SCC1 via MIDI cable (I use the mini-dyn adaptator). The cable goes from the SCC1's OUT to the MT-32's IN.
Obviously I set the games on MT-32.
Reply 4 of 10, by keropi
check your BIOS for an ACPI setting if it can be disabled or switched to APM , ACPI is hardwired to IRQ2
Reply 5 of 10, by Obiwan
ACPI is already disabled.
I should tell I did run any program after SCC1 installation: CHKSCC.exe tells me an other card uses the same adresse (330h-331h).
Reply 6 of 10, by Obiwan
up!
I need one clarification: is it possible to switch sound between the MT-32 and the SCC1 part or is it mandatory to have both streams?
Reply 7 of 10, by badmojo
The SCC1 will always output sound when you send MIDI data to it's MPU401 - if you're using an MT-32 attached to it then you just have to ignore output from the SCC1 - i.e. mute it via your external mixer, unplug the cable from the RCA or headphone jacks.
Reply 8 of 10, by Obiwan
thanks you for your answer!
Nevertheless I need to modify my first statements: while playing X-wing: the SCC1 plays the music (with some different instruments). The MT-32 plays one hanging note (some kind of larsen).
I know some games have hardcoded settings for soundcards (factory settings). Maybe that's it! You can't choose any setting in X-wing.
Reply 9 of 10, by badmojo
What have you selected for music in the Xwing sound setup application (setmuse from memory)? General MIDI for SCC1, and I think it's just listed as 'Roland' for MT-32. Both devices will produce sound but one will sound wonky depending on your selection.
Reply 10 of 10, by Obiwan
I picked Roland + SoundBlaster to test the MT-32.
