Undocumented instruction
First post, by kekko
some days ago I tried to run norton sysinfo on emulated
system and discovered that the program calls instruction
ffh 07h (two-byte opcode in group 5)
that is officially unsupported by intel.
of course the program crashes!
Does anyone knows which instruction is it?
Is there a way to understand and implement it
studying the execution of the opcode on a true cpu?
thanks!
Reply 2 of 3, by kekko
Already done: nothing.
somewhere I saw that using softice with the program
on a true cpu i can obtain the behavior of the instruction
but I don't know how
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Where did you get that from? It's a standard INC,
just look at the address harekiet mentioned.
I guess you are mislead by the dosbox output
GRP5:Illegal Call 7 which is not 0xff 0x07.
It occurs when the program flow gets wrong, in
this case a zero pointer from int21/65 i think.
wd
