First post, by xjas
Looking for a monitor arm to hold my "CRT replacement" Dell 2001FP (or maybe a dual-monitor stand as I'm planning to get another one 😎 )
I'm after something that can do this:
202.85 KiB
(Sorry for the crude drawing)
Nowhere in town seems to stock these; I don't want to order online "blind" and end up with some cheap flimsy thing. That said, I don't want to pay an arm and a leg either. Any of you guys know of a good one?
Reply 1 of 4, by gdjacobs
Can you make do with a standard swing arm mount? I think it would reach far enough if you have the vertical clearance for the pole stand.
5.96 KiB
No downloads
Reply 2 of 4, by bestemor
I love this one, even bought an arm extension for it.
https://www.amazon.com/Desk-Mount-LCD-Tall-Po … e/dp/B00689HXI4
Not cheap, but oh so robust and very flexible 'settings'... 😁
The arm can be mounted anywhere on that pole, so for your purposes it'd probably be at the bottom.
Granted, it has no telescopic(!) arms, but I cannot imagine such a thing would exist (all that friction inside the tube when heavy monitor on the far end..?).
Is lateral shelf space the problem here, or....?
PS: the short pole version is $30ish cheaper, if you don't think you'll ever need that xtra height flexibility.
https://www.amazon.com/LX-Desk-Mount-LCD-Arm/dp/B00358RIRC
Reply 3 of 4, by xjas
It doesn't have to work exactly like I've drawn, I just need something that can put the monitor in those two positions & can easily be adjusted on the fly. 😀 Something like ^^ that would work fine (but man it's expensive! Get what you pay for I guess.)
Reply 4 of 4, by gdjacobs
As long as the arm extension is enough, I think something like this would be good for you. The knuckle by the monitor allows vertical tilt and the pole allows height adjustment.
