First post, by anetanel
Hey guys.
I got my hands on a sweet AMD 286-16Mhz pc. It came with an ISA "Super I/O Card" with an Acer M5105 A2 chip (picture attached), but without an HDD.
I added a WD Caviar 2200, 212.6 MB HDD, and configured it in the BIOS according to the writing on the disc - but every time I boot, I get an error message: "fixed disk controller failure". I need to press F1 to continue booting from floppy, or F2 to enter BIOS.
I am able to boot from a Gotek floppy emulator, and once I'm in DOS (MS-DOS 5, if it matters), I can access the HDD without any problems.
I've partitioned the disc with FDISK, formatted it, copied files, games etc. and all seems to work without a hitch. But even though I've formatted with /s and I can see the system files, it still shows the above message and won't boot from the HDD.
I tried each of the 2 connectors on the IDE cable, replaced the IDE cable altogether, changed the card slot.. but no success.
Any help is appreciated 😀
    645.68 KiB
    super i/o card. acer m5105 a2
Reply 1 of 12, by .legaCy
anetanel wrote:
Hey guys. I got my hands on a sweet AMD 286-16Mhz pc. It came with an ISA "Super I/O Card" with an Acer M5105 A2 chip (picture a […]
Hey guys.
I added a WD Caviar 2200, 212.3 MB HDD, and configured it in the BIOS according to the writing on the disc - but every time I boot, I get an error message: "fixed disk controller failure". I need to press F1 to continue booting from floppy, or F2 to enter BIOS.
Did you tried "fdisk /mbr"?
Reply 2 of 12, by derSammler
"fixed disk controller failure" is something you normally get with IDE when the CHS parameters are incorrect. Are you sure you have entered them correctly in the BIOS? Should be 958/12/34.
Reply 3 of 12, by anetanel
.legaCy wrote:
Hey guys.
Tried now.. didn't change much.
Reply 4 of 12, by anetanel
I am positive that I entered the correct parameters. But according to the writing on the disc, its 989/12/35. I tried the parameters you wrote, but I still got the same error.
Reply 5 of 12, by bloodbath2you
also, make sure the jumpers on the card are set correctly and the IDE is enabled, if not will display this error.
Reply 6 of 12, by alvaro84
Me experience with old WD caviars is that you should just remove the jumper to set it to master. No matter what the sticker says.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 7 of 12, by Jo22
Hi, I'm not sure what's the problem exactly, but as a least resort, you can give S0Kill a try.
It'll remove any spurious data at the beginning of the fixed disk. Whatever mixes up the boot process should be gone by then.
(But becareful: Before you do, please don't forget to backup any important data on that HDD.)
Reply 8 of 12, by anetanel
Thanks for the advice. I'll try to play with the jumpers.
I couldn't find any place to change IDE settings though.
Reply 9 of 12, by anetanel
Thanks. I'll try that too. There's nothing on the disk that can't be restored rather easily 😀
It could be a bit of a hassle to copy it with floppies, but it may just be a good reason to try to find my old laptop with LPT port and use Norton Commander to copy files over the wire 😎
Reply 10 of 12, by derSammler
He can read the files on the HDD when booting from floppy. So IDE is surely enabled and jumpers are probably set correctly, too.
Reply 11 of 12, by Predator99
Yes agree, IDE configuration seems to be OK. The problem is with the BIOS setting. Can you make a screenshot what else can be adjusted?
Does your mainbaord have an additional onboard IDE?
What happens if you select "no disk" in the BIOS? Still the error message?
Reply 12 of 12, by anetanel
Dude! That worked!
I was sure (as others here) that since I can see the disk when booting from floppy, it is configured correctly.
Thank you very much.
I already ordered another IO card from Ebay 😜
I guess it doesn't hurt to have a spare...
