First post, by CaelThunderwing
few games i always have trie dto make run on certain systems is Monkey Island & Willy Beamish & BASS.
now i dont have toomuch of a problem to make MI1 2 and BASS in ScummVM, Except The Adventures of Willy Beamish. i'm fully aware there's no official DGDS engine in any Stable build, and that development on the DGDS Engine Stalled 5 years ago! (which would put it at what... 1.2.0 or 1.2.1?) and the last commit stating there were fixes of compiling dgds with newer versions.
now i do have a "Usable " Build enviroment setup but its all centered for 3DS homebrew (i dont know wtf i did but anytime i try to comppile anything w/ a PPC target, g++ crashes) and i cant even compile 2.0.0 Normally.
now if its possible anyone could buildthe last version w/ DGDS or if 2.0.0 'll compile w/ the Engine targeted for OSX/PPC Target.
now the talk about performance..
i've seen how POOR Dosbox is on a Quicksilver G4 (800MHZ) and is bearly acceptable on my Dual G5(not dual-Dualcore (aka the "Quad-Core G5") but the Dual Single-Core Model.
since ScummVM isnt Emulating the Other aspects of a x86 System only interpreting the game's engine (if i understand how ScummVM Differs from something like Dosbox) so shouldnt performance be far better in ScummVM vs trying to run the game in VPC 6.1?
Reply 1 of 7, by derSammler
Yes, but why don't you just try it?
Reply 3 of 7, by derSammler
He doesn't even need to, as 2.0.0 for OSX/PPC is officially available: http://scummvm.org/frs/scummvm/2.0.0/scummvm- … -macosx-ppc.dmg
While it doesn't have the DGDS engine included, it's enough for speed comparing, which seems to be the main question. If games don't run faster on that compared to DOSBox, it's wasted time to compile an own build with DGDS enabled.
Reply 5 of 7, by CaelThunderwing
cant test how it Will work w/ ScummVM (The Adventures of Willy Beamish) because its another Dynamix game that uses DGDS but 3 i tested on the system, do play full speed as Long i dont try MT-32 Emulation. will check later the G5 soon as my roomate comes home w/ its Replacement SATA HDD (i dont exactly like using it too terribly much the G5's of Any model were power hungry Models enough so i haveto shutdown my main rig as my UPS cant handle the load of both)
EDIT: now that i got teh drive setup OSX 10.5all the updates, i got to testing it.. its bearly "Passible" in dosbox (Willy Beamish) as for ScummVM, same performance mostly outside that while audio lags like hell w/ MT32 Emulation on, Enabling it doesnt make teh computer keil over.
Reply 6 of 7, by mr_space
Dominus wrote on 2017-12-28, 12:55:
Btw. My SVN snapshot of DOSBox is for PPC as well, for comparison
Indeed, it used to work great, I got a blank screen using opengl output the last two releases though, on Tiger, thanks anyway!
