First post, by Cobra!
I'm trying to install a CD copy I have of Half-Life 1. However, the installer doesn't run at all, no errors, it just does nothing, nothing appears at all, and I need to go to task manager to close it.
I've tried copying the CD contents over, and replacing the installer (since it's 16-bit InstallShield) with a 32-bit version, but that didn't work either. I got the same results.
I've already tried redeeming the CD Key on Steam, but that didn't seem to work, it says it was already used.
What do I do?
Reply 1 of 17, by ZellSF
Kill non-Microsoft background processes on your system one by one until you figure out which one interferes with the InstallShield installer.
Reply 2 of 17, by SpeedySPCFan
Run the installer, close it out it in Task Manager, and quickly open it back up (within like 3 seconds or so). If this is what I think it is, then it's just Microsoft enforcing their ludicrous security measures.
Did you by chance buy the game used? Someone likely snagged the key from the eBay photos, or redeemed it back when Steam was new. You really shouldn't buy any of the GoldSource games used for that reason, unless you just want the original WON release of the game.
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Reply 3 of 17, by UCyborg
Start the installer, then the Resource Monitor, find setup.exe in the process list, right-click on it and select Analyze Wait Chain... That will tell you which process is it waiting on; you must kill it.
PS: I have GOTY Edition with installer SETUP.EXE dated 1st October 2001. The game itself is at version 1.1.0.8. The installer doesn't have this issue, it's Wise Installer rather than InstallShield. So there are different versions of GOTY Edition out there?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 4 of 17, by leileilol
The installer on my copy of HL works absolutely fine on 7 x64..... and it IS Installshield-based.
(HL GOTY should be 1.0.0.9 from Sep 1999 at the latest fyi.)
Reply 5 of 17, by UCyborg
One ad on Amazon also says that this is the version needed for certain mods to run. It mentions They Hunger and this one needs at least 1.1.0.0 to run. The latest official patch for the WON version is 1.1.1.0. So it looks like there are different versions out there.
Anyway, regarding InstallShield problem, it has nothing to do with Windows version. It just doesn't work for some people because they have a misbehaving program running in the background that doesn't respond to the window message that is broadcasted by InstallShield to all windows on the system by the means of SendMessage API function.
Oh yeah, you can reproduce the problem with InstallShield easily on your own. Get Process Hacker 2, start Notepad, then use Process Hacker to suspend notepad.exe. You can suspend most Win32 applications that have any sort of window, including invisible ones and you'll see what happens.
Reply 6 of 17, by Srandista
Hmm, I dig my old CD of Half-Life, and even though its older then your GOTY (version 1.0.0.9), I was able to install it and also run it on my Windows 10 64-bit without issues.
But, I have a similar problem like you with original Unreal CD, and I solved it just by running that installer on my virtual Windows 98 machine. Once it finished, I just copy installed files from there to my main system.
Reply 7 of 17, by leileilol
Unreal doesn't really need an install though. One could just copy the folders directly from disc and run it from there...
Reply 8 of 17, by Srandista
Yeah, I found that later, when I compared content of game dir with content of CD. But with this method I'm almost certain, that Cobra! would be able to install his copy of HL GOTY.
Reply 9 of 17, by leileilol
Nope. It's all in a cab.
Reply 10 of 17, by Srandista
No, I mean installing in either virtual machine or real retro Win98 machine.
Reply 11 of 17, by Rekrul
Does that work for the Gold edition?
Reply 12 of 17, by schmatzler
Yes.
What else was I supposed to do back when I was in school? 🤣
Reply 13 of 17, by blam666
I could install my Half Life 1 retail relatively trouble-free recently on WIndows 10 64, but for recognizing the disk I had to update to 1.1.1.2. There I stayed.
Runs fine, but I have this bug now that the screen stays black when I return from game environment to menu.
This is not a devastating blow for gameplay, as you can easily just press the Windows key, activating the task bar, and repress it - and menu shows up again.
Still annoying, though. Does anyone know this problem and hopefully even a workaround for it? Most support site only care about steam versions nowadays...
Reply 14 of 17, by leileilol
HL's old menu system was notoriously buggy even on Win9x. There are no fixes besides getting Steam and playing their updated Half-Life on that platform as that has a new, bit more bulletproof menu system.
Reply 15 of 17, by blam666
Ok. Does the Steam vs. still look the same, though? With the sierra intro, the yellow on black fonts etc.?
I can be an awful pedant about these things, sorry.
Reply 16 of 17, by leileilol
Nah they dumped that all for a gray on black scheme plus green windows (to match the Steam interface they had pre-2005)
Reply 17 of 17, by blam666
Thought so, grrrr.
