First post, by bristlehog
I've just got one. It's a 1989 variant of IBM M-ACPA card.
Seems it uses interrupts and shared memory window (no DMA). Any ideas on how to run it under DOS? Anybody knows anything?
I've seen these resources:
http://ps-2.kev009.com/ohlandl/sound/ACPA.html
http://ohlandl.ipv7.net/sound/ACPA.html
Thing is that I've got seemingly different version with other jumpers and switches. If someone had the experience or the ideas I'd hear that to simplify the process of getting acquainted with this long-forgotten and unpopular card.
Update: I managed to run the card almost without trouble. It supports PCM sound and some Adlib-like synthesis for MIDI music.
Recordings
Hardware comparisons and game system requirements: https://technical.city
Reply 1 of 17, by cyclone3d
I recently acquired one of these as well but have yet to test it.
I had another one over 20 years ago and ended up getting rid of it because I couldn't find any information whatsoever about it.
I'll post back here once I get it installed and tested.
Hint: The newest beta drivers are supposed to have Sound Blaster support.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 17, by bristlehog
You need to manually create a new MIDI map in your MIDI Mapper, if you want MIDI to work in Windows 3.1. It's described here: https://www.youtube.com/watch?v=qkk0YW_qd-Y
Reply 3 of 17, by squiggly
I've never quite got the connection between FM Synthesis and Midi. If FM synth can be used to generate Midi sounds without a wavetable....why can't I select a wavetable-free card as General Midi in games? To do that, I *need* a wavetable device connected to the internal header or the gameport. FM synth sounds more like what you would use to generate sound effects.
Reply 4 of 17, by cyclone3d
Some of this is going to be sorta off-topic, but it is one of the things I am very interested in so here goes.
It really depends on the implementation. FM is addressed on a certain range of ports depending on if you have single or dual FM, while MIDI is addressed on a different range of ports.
There is a Windows driver software that allows you to use OPL3 as a MIDI device. I am guessing it would work if you play DOS games from within Windows but I haven't tried that yet.
http://www.midiox.com/html/fmsynth.htm
There are also midi players that use the FM to play the MIDI files.
http://vgmrips.net/forum/viewtopic.php?f=15&t=1935
https://bisqwit.iki.fi/source/adlmidi.html
FM MIDI was a huge thing back in the day.
Go take a look at what the old FM synthesizers could do.. such as the Yamaha DX7 and DX7II range (I have a DX7II FD that was working but completely died for no obvious reason.. makes me sad).
I also have a Yamaha SY99. I've really got to make use of it once I get other projects finished.
Then take a look at what the Yamaha SY series can do. FM+Wavetable.. pure awesomeness.
https://en.wikipedia.org/wiki/Yamaha_SY99
And Yamaha's newest keyboards have gone back to FM+Wavetable after years of dropping FM. I really, really, really, really want a Yamaha Montage keyboard.
https://usa.yamaha.com/products/music_product … tage/index.html
Watch/listen to some music made with these keyboards... with a good sound setup to get the full effect.
YMF7x4 Guide
Reply 5 of 17, by bristlehog
FM synthesis is a type of synthesis that was adapted to play MIDI music when there was little to no sample-based synthesis.
You can't because Adlib and other FM sound cards aren't MIDI compatible. With MIDI-compatible cards you write MIDI commands into the card's ports and get music playing, like this:
select instrument A on channel B
play note X with duration Y
FM synthesizers like Adlib don't know anything about instruments and MIDI, they only can synthesize sound with given parameters, so there is nowhere to send MIDI commands. After MIDI gained huge popularity with DOS game development, a workaround solution was invented: a middleware driver that accepts MIDI commands and converts them into FM synthesis commands using a table translating each General MIDI instrument into FM control information.
This is the way it works in, say, Warcraft. Game's music engine sends MIDI commands to a middleware music driver, and it cares not about how on earth the driver is going to make hardware play. If a General MIDI sound card is selected in setup program, then the middleware driver just passes the MIDI commands to the MIDI port and that's it. But if there's an FM sound card selected, then the middleware driver loads it's GM-to-FM bank and sends corresponding FM commands to Adlib's port.
For Warcraft, the mentioned middleware drivers are:
drivers\mpu401.mdi - General MIDI
drivers\adlib.mdi - Adlib
drivers\warcraft.ad - GM-to-FM bank for Adlib
Reply 6 of 17, by squiggly
Interesting, so it is very game specific. I suppose some games might make use of GM through the MIDI port if selected, but if FM is selected generate different music entirely (rather than converting GM to FM on the fly)?
Reply 7 of 17, by bristlehog
Of course. An example of a game that uses different music file formats for different hardware is UFO: Enemy Unknown. It has MIDI files for generic MPU-401 devices, but for Adlib and compatible sound cards it uses some files containing FM commands.
Some games, like aforementioned Warcraft, while using middleware drivers, nevertheless use different sets of MIDI files for different hardware. Warcraft has different MIDI files for GM and FM hardware, although the differences are not very expressed.
Offtopic: my, I'm so educated in the subject and so craving for attention! Perhaps I should write an article.
Reply 9 of 17, by bristlehog
Recordings of Tecmar ARPA:
Doom - E1M1
Heretic - E1M1
Warcraft II - Human theme #2
Tyrian - Asteroid Dance Part 2
Dune II - Title
UFO: Enemy Unknown - Lose
It's obvious that I was mistaken calling it Adlib like synthesis. It's nowhere close to OPL, I have no idea what kind of synthesis it is. Alas, it seems that the MIDI driver doesn't support pitch bends.
Feel free to request music to render on Tecmar ARPA. Note that due to channel restrictions complicated tracks cannot be played properly - some instruments might be missing in tight passages.
Reply 10 of 17, by cyclone3d
That doesn't sound half bad.
What are the specs for the system you have it installed on? I am wondering if the card is speed sensitive or not.
In other news... I need MOAR ISA slots!
YMF7x4 Guide
Reply 11 of 17, by bristlehog
Compaq Presario CDS 762 - with a Socket 4 Pentium 60 at the heart of it, and a built-in Sound Blaster compatible sound card - meaning that Tecmar ARPA doesn't conflict with one, at least on default settings.
Reply 12 of 17, by Unknown_K
504.5 KiB
I have the revision B and it looks nothing like yours.
Reply 13 of 17, by peklop
Thanks for records! Please can you upload Duke Nukem 3D theme?
Reply 14 of 17, by bristlehog
Nope, I sold the card already.
Reply 15 of 17, by peklop
Sad news but thanks for posted recordings.
I have questions. Is IBM M-ACPA only MCA version of ISA ARPA? DSP is same .
Is music synthesis same for both cards?
Whas synthesis is it? Sounds like FM. Was TMS320 DSP chips used for FM emulation?
Is chip so less poweful compared to mWave DSP? Because IBM mWave DSP synthesis sounds like relative good wavetable card compared to poor ARPA.
Reply 16 of 17, by bristlehog
Seems so.
Seems so.
> What synthesis is it?
I don't know. It sounds not much like FM, but not much like sample-based synthesis either.
Reply 17 of 17, by yawetaG
This document, found on one of the pages you linked to in your first post, explains two synthesis methods that the cards can use:
http://ps-2.kev009.com/ohlandl/sound/spra355.pdf
Looks like an early physical modelling implementation... Some bits also resemble proper wavetable synthesis (i.e. not Creative's misnomer).
