Are you sure that there are no other sound chips there? It looks to me like the CS4231a is just a codec chip.
The CS4231a is a newer/upgraded chip compared to the CS4231 and CS4238
Looking through google images, I see it paired with:
Opti 924, 925, 929, 930
MAD16
Mozart
Aztech AZT2316R, AZT1605
Edit: Have you tried installing the plain Windows Sound System drivers?
Also, see this thread.. looks like it can be paired with basically whatever:
Microsoft Windows Sound System standard support in DOS games
EDIT 2: Here is information about and the files for the CS4231 DOS/Windows drivers
These are the installation instructions for The DOS/Windows drivers:
http://greyghost.mooo.com/pccbbs/commercial_d … top/qd2t00a.txt
DOS 6.2, 7.0
Microsoft Windows 3.1, 3.11
You can browse the folder by taking away the .txt file
http://greyghost.mooo.com/pccbbs/commercial_desktop/
The OS/2 driver package (cryst211.zip) mentions the Windows driver file names.
Windows drivers seem to be disk images which I haven't tried extracting... Crystal1.exe and Crystal2.exe which I have attached to this post.
- Filename
- crystal1.exe
- File size
- 760.68 KiB
- Downloads
- 216 downloads
- File license
- Fair use/fair dealing exception
- Filename
- crystal2.exe
- File size
- 722.98 KiB
- Downloads
- 194 downloads
- File license
These are for the CS4231, but maybe they will work for the CS4231a.
EDIT 3: And here is a set of DOS/Win3.1/Win95/98 drivers for the CS4231a
http://www.soundcard-drivers.com/drivers/66/66506.htm
- Filename
- cs4231a.zip
- File size
- 1.88 MiB
- Downloads
- 213 downloads
- File license
