soundblaster 32
First post, by scroeffie
where and how do i install drivers for my ct 3620
Reply 1 of 36, by jesolo
Bit of a vague question.
What system are you running? DOS, Windows (which version) or, a combination of both?
Drivers are available on Vogonsdrivers - you can even use the AWE64 drivers to install, depending on your operating system.
Reply 2 of 36, by scroeffie
winodws 98 drivers wont work and some drivers are in frensh
i tried the driver for creative website but windows wont exept the drivers
tried the 190mb install cd windows says i need to intsall drivers first
Reply 6 of 36, by jesolo
Does your PC (the BIOS) detect the Plug and Play sound card when you boot up (this is a PnP model, so your BIOS should detect it, depending on whether you have a PnP BIOS)?
What is your system specifications?
Reply 10 of 36, by scroeffie
so i need to install the drivers first for my sounblaster 32 ct 3620 but where are they ?
oke windows sees the creative vibra 16 card ! so the problem is the sounblaster ct 3620 < seller told me it worked 100%
Reply 11 of 36, by derSammler
Why don't you just follow the instructions that the "error" message gives you? You try to install the bundled applications, but those require the drivers to be installed already. The drivers are on the CD as well, most likely in a subdir called drivers/win9x or something.
Reply 12 of 36, by scroeffie
the soundblaster 32 ct3620 has broken traces that fucker on ebay told me it was working 100% i never chekked if it had any broken traces etc wtf !
i installed a vibra card now it works oke has popping noise better than nothing
    57.53 KiB
    365.02 KiB
Reply 15 of 36, by cyclone3d
scroeffie wrote:
wel windows wont see the card ,i just put in the vibra card and windows sees it installed the drivers and its working perfect
I also don't see any broken traces.
What does the front of the card look like? Are there any chips that have the legs bent or broken?
Did you actually ever try to install the actual drivers for the SB32?
It is not going to be detected exactly like a Vibra 16 card.
You may need to run the diagnose program from within DOS to set the PnP configuration to work with your computer.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 16 of 36, by scroeffie
i tried to install these drivers sbw9xup.exe
Bestandsgrootte : 311,97 KB Downloaden
Details weergeven
Releasedatum : 13 nov 98
Full duplex Sound Blaster 16/32/AWE Driver Updates for Windows 95/98 SDR-95UPD-1-US (Revision 16 / but i could not because windows was not showing the souncard
dont know how to install them via dos
Reply 18 of 36, by jesolo
Being a PnP card, if Windows does not detect the card upon start up, then there is probably something wrong with the card.
You could also try to detect the card via the Add New Hardware wizard within Windows.
If no luck, then I would return the card to the seller and request a refund.
Reply 19 of 36, by cyclone3d
scroeffie wrote:
see pic
Ok, so with the closer picture, one of those traces looks like it is cut.
That's a bummer.
It could be a really easy fix though. Maybe contact the seller and see if they will give you a partial refund if you can fix it and if not, then send it back for a full refund.
YMF7x4 Guide
