First post, by Guest
								Guest
								Offline
			I keep getting this error when trying to run Jane's ATF combat sim.
Abnormal program termination: Memory protection fault
CS:EIP = 00C3h:000018B8h
The syntax of the command is incorrect.
I'm using the newest version of DOSBox (0.61), have drive C: mounted and drive D: mounted as cdrom.  Any ideas?
